Routing
“Webinar
Labels
 BST: %IOSXE-2-PLATFORM: R0/0: kernel: EXT2-fs error (device sda1): ext2_lookup: deleted inode referenced: 3170306  BST: %IOSXE-2-PLATFORM: R0/0: kernel: EXT2-fs error (device sda1): ext2_lookup: deleted inode referenced: 3170329  BST: %IOSXE-2-PLATF...
I am setting up a C1111-8PWA-WS for the first time.  After not being able access the internal wireless card I decided to set up without it.  I have a Cisco SG350-28P switch that has POE for the AP's.  Trying to set up the basic unit with just the rou...
Hi, I have a ISR1100 (C1111) with two connections: fiber (GiE0/0/0) and LTE (Cellular0/2/0). Config excerpt:ip route 0.0.0.0 0.0.0.0 100.64.107.1 name primary track 1ip route 0.0.0.0 0.0.0.0 Cellular0/2/0 10 name backup!ip sla 1icmp-echo 8.8.8.8 sour...
Sakura by Level 1
  • 883 Views
  • 19 replies
Thank you for your help.There is no power button on the Catalyst9000 switch, but is it okay to pull the power cable out of the switch when it stops?In the case of a ISR4000 router, a soft shutdown is required by the reload command in advance, but I w...
Translator by Community Manager
  • 83 Views
  • 1 replies
You are attempting to activate your license in a CSSM offline manner.An error occurs when exporting a RUM file.Do you have a response method? Model: C1111-8P Router#license smart save usage all file flash:test_rum.txtThe requested item was not found ...
  • 56 Views
  • 0 replies
This is very high level, wanting to know if this is possible.  We're the middle man.  I don't have access to or knowledge of equipment or configs on the other providers.  Currently we are handed off a GRE tunnel to a router.  We have an ipsec tunnel ...
We have a FlexVPN Setup where Spoke2Spoke connections get created dynamically with the help of virtual access interfaces. So if i want to edit something within a virtual-template, i get the error that it is locked:  router(config)#interface Virtual-T...
je trouve cette output anormal, que pensez vous SVP de l'état ospf dasn ce cas :O E1 10.232.51.3/32 [110/53] via 10.4.151.2, 12:16:54, Port-channel20.1017[110/53] via 10.4.151.2, 12:16:48, Port-channel20.1017[110/53] via 10.4.151.2, 12:16:54, Port-ch...
Hi.I have one Cisco ISR 4321. This is a brand new router and I am the first owner.I have encountered the following fault since the first start up:It keeps restarting at random intervals. Sometimes after 10 minutes but sometimes it lasts for 2 hours.T...
Hello Everyone I have to set up an ipsec tunnel with Lo0 as source of tha tunnel. Nat is activated in My CE and in the ISP level (NAT444)All ipsec and Nat configuration is ok but, and as I know that for the NAT to work correctly, the packet should pa...
mrkassimi by Level 1
  • 327 Views
  • 7 replies
