Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3642 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5326 Views
  • 1 replies
  • 16 Helpful votes
Hello, I've upgraded my SG350 28MP to the last available version. Since the upgrade, I'm not able to login to the switch anymore. I've tried to reset it factory default multiple times, the default credential (cisco/cisco) are not working. What are th...
davben by Level 1
  • 1328 Views
  • 5 replies
We have switches with expired smart-net support that have failed to bring the interfaces up due to power inline failure during post. I formatted the flash and put images designed for non-POE switches to see if the inline power failure status during p...
I have the above device connected to my Verizon Router using the 192.168.1.2 | 255.255.255.0 for its' management IP under VLAN 1. I have ports gi2-3 configured for VLAN 100, using 192.168.100.1 | 255.255.252.0. VLAN 1 is configured as a trunk port. I...
Mork1978 by Level 1
  • 362 Views
  • 0 replies
I have Cisco SG300-28, SG350-28, and Catalyst 2960 switches. SG350-28 and Catalyst 2960 are connected to SG300-28 via a trunk. The Bridge Priority of Cisco SG300-28 is set as 4096. However, the Catalyst 2960 switch sees it as root bridge only for VLA...
sakar by Level 1
  • 2671 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
