Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2647 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4178 Views
  • 1 replies
  • 16 Helpful votes
Picked up an 8 port SF302 on the fly to replace a 2960 that has failed. Attempting to config for use with DATA and VOICE vlans. Device port G1 is connected to 0/1 on a 2911, which has 2 sub-interfaces- 1 each for voice and data. Cannot get switch to ...
I have a question on how to setup an ACL configuration on the SLM2024.  I originally got this switch to just be able to monitor network ups/downs on the ports.  and this has worked great in diagnosing the problems I was having originally.  Now howev...
Hello,I am using a couple cisco sg300 28P switches along with a sonciwall firewall/router. The sonicwall was already in place and working so they didnt want to replace it. I understand how to configure the vlan on the sonicwall, but could use some he...
Hello,I have a SGE2010 and have one static LAG going to each of my (two) ESX servers.  From my testing it seems that the LAG speed is maxing out of 1Gbps.  I am unable to get anything faster than that.  I cannot find the load-balancing algorithm that...
Pcfreek14 by Level 1
  • 965 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
