Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2614 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7250 Views
  • 4 replies
  • 17 Helpful votes
Hi all, noob here pls don't be too harsh.I have a kind of a small business setup with about 20 workstations and a physical server with some (yet unidentified) virtual machines.Domain controller is not some local sever, it is cloud-based: MS Entra ID ...
kraljmase by Level 1
  • 6198 Views
  • 7 replies
Hi,I have a problem with this configuration as of certain FW. I know version 3.1.0.17 was OK and current one 3.4.0.17 is not and unfortunately it is not possible to downgrade to confirm the issue. I am running DANTE alongside WYrestorm Network HD vid...
Trying to set up new sg350  10 p - tried using the config file from one used and working but it failed and needed factory resetmy other one has the leds turned off so have no idea what I should see ports 1 to 8 light green on left light only when usi...
finn by Level 1
  • 343 Views
  • 0 replies
Cisco 3650 uplink to router is going into sfp port 1/1/4 and shows operational status down ?I have it set as a a trunk port on the 3650 and is connected to a 10 gb SFP port on a tp-link switch which shows it is connected The port is obviously connect...
spd2612 by Level 1
  • 2487 Views
  • 14 replies
I've recently deployed a 2x CBS350-48FP-4X stack and the CPU is pinned at 100% during production hours. There's a 2x CBS350-24FP-4X stack in the same location at the access layer with an almost identical config and that thing is fine.This problem exi...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
