I thought that with the EHS added in the 2013 firmware upgrade a Jabra PRO 9470 could lift the handle via the cable 8800-00-75. But Jabra says it is not possible, and it will not come either! Are there any headsets that offer this for the SPA525G2 wi...
The newest firmware for the SPA525G made EHS available, but when I look in the compatibility guide http://goo.gl/RBO9qN, it seems as if you need a cable to connect the phone to the headset base. I wonder is this because the compatability guide has no...
Hi guys, Gone thru and configured everything thru CCA - the latest. I am having inbound call quality issues with the audio breaking up. The box is directly connecting thru a switch to a public ip. Doing a speedtest thru my ISP ( I have 100/5 c...
Phone is crashing and rebooting when receiving or calling with the bluetooth mobile pairing with a Galaxy S4.Software loaded is latest 7.5.5bI know galaxy S4 is not in the supported list. But the list seems very old.Would I get more luck with an Ipho...
I have a customer with an analog pbx system now that I am changing over to a sip system. They have a few lines that need to still have analog connectivity so I am installing a Cisco/Linksys SPA8000. One of my issues is with a 2-way PA system between ...
Hello,We have recently migrated a client from an in house exchange server to Microsoft Office 365. We have also set up a connector on Office 365 to relay mail from devices such as scanners, locked down to our external IP address, which is working we...
We have a UC560 with a PRI using Single Number Reach. When a call is sent to the users mobile phone they see the companies main number on their caller ID. Can we modify this so that that caller ID sent is from the originating caller?
Hello, I have a problem trying to configurate a be6000, i have a Router, a Switch and my BE6000, but when i'm trying to configure the NTP in my BE6000, it doesn't work, i have to say that i'm redirection my BE6000 to my Router to take the NTP...someo...
Hello,My UC560 user options web page //ipaddress/ccme.html only has one configuration option for users and I cannot figure out how to make the others available. There's no CM server. Does anyone know what the issue is and how to fix it? Thanks.
Hi everyone,I working for ITSP. We have many of this product with different firmware(1.3.0 - 1.3.3).When i set SRV redundancy enable on the SPAs, after about a month they crash at same time .If SRV off there is no problem.It could be a memory leak o...
Hi:I have about 25 Cisco SPA504 phones connected to a UC560. I have a question, 4 of the phones are members of a blast group so when and inbound call comes in all 4 phones ring simultaneously. Now the question is, can I, somehow, install a wall or ce...
Hello I need your help, i have few SPA504G phones stuck in SOS PhoneInRecoveryMode, image corraptedHere is solution how to recover the phone with recovery software, but nothing helpshttps://supportforums.cisco.com/document/37666/spa50xg-ip-phone-reco...
I couldn't connect pc by ethernet cable with spa2102 typing the given ip address 192.168.0.1 so I tried connect via modem-router dialing the command ****7932# but the adapter response was that this is a invalid function or operation.Can somebody give...
