Hellohow can i connect spa 301 with spa 9000?the spa 301 is registered in spa 9000 but the light is orange!Hello every oneI would be glad if someone help...---Posted by WebUser Keyvan Ebrahimi from Cisco Support Community App
We have a UC-540 and have an issue that when outgoing calls are placed through our PRI the User's extension name is sent for the Caller ID. The number set in the outgoing caller ID field is sent correctly, but is there a way to send the Company name ...
Dears,any one can help me on this issueFXO Lines lock-up when a call comes in and it is forwarded to another external number, we have two PSTN fxo lines being used updebug as belowUC_iSupply#sh voice port summaryIN OUTPORT CH SIG-TYPE ADMIN OPER ...
BU slides show that BE6000 customers are entitled to use UPM 9.0, the "enterprise" version as well as UPM-BE, that ships with the BE6000 bundle. I understand that because UPM 9.0 does not ship with the bundle, customers can order via PUT. However I...
Hi All, We had multiple reports on issues ordering BE6K-St-BDL-K9=. When order Smartnet service on the server without service on VCS licenses, CCW will make the configuration invalid. This issue is solved now. You should be able to order Sma...
I have two sites, one with a UC560 an another with a UC540. I manually created a VPN tunnle and setup dial peer. The two sites can use 4 digit dialing and have access to the PSTN from each site. Calls from IP Phone to IP Phone work just fine.However,...
Hi,I have attached a 7916 Exapnsion Console, to a 7970 IP Phone.In CCA when configuring the phone, it only shows an option to choose 7914 or 7914x2 for the connected expansion console.I tried going through CLI, then changing the type 7970 expand 7916...
Hi All,I have the following call routing setup on a UC540.Incoming Call => AA ext.298 [caller is greeted with custom greeting] => No Option Transfer to Blast Group ext. 511 .....now the caller waits to be answered by a representative.What I would lik...
I have a problem and I can't figure out how to solve it.I have multiple SPA509G phones and on ech phone we have multiple lines/phonenumbers.When we have a incoming call we only see the phonenumber of the caller on the display.We want to see the short...
I noticed while configuring some phones that if you "?" for "type" under "ephone"... there are 2 interesting options that appeared at some point: DSPA Cisco SPA Phone desktop client MSPA Cisco SPA Phone mobile clientI wonder if these are canc...
Hi GuysI have a problem. I´m following the configuration guide for Installing OpenSSL and Generating a Certificate for Cisco Unified Provisioning Manager 8.6 on Linux, but I can´t find the install-directory/httpd and /opt/cupm directory, to upload th...
have understood that the UC320 handle up to 9 FXS. I also know that I can connect up to 2 SPA8800.but my question is: I can use a SPA8000 with the UC320? and especially from the CCA to configure it?Thank you.
Hi Commuity.I have successfull installed Jabra Headsets with a 7942 phones. The hint with the service phone ehookenable in the the telephony-service works well.But whats the hint for SPA525G2 Phones. They doesn't recocnize the service phone ehookenab...
Hello ladies and gentlemen,We have recently acquired a UC540 and are trying to set it up along with a few different ip phones. I resetted the UC540 and am now recieving an IP from the dhcp of the company, even though not the default address. The prob...
