can someone please tell me how to configure the spa942 to show my outbound number when calling them....it shows the old number i had on it still. thx
We have a customer with a UC560. It's setup with Paging (ext 250) and Park lines (4 of them). Typically when an inbound call is received, the operator will PARK the call then hit the preconfigured PAGE button to inform whoever it is to pick up and wh...
Is it possible to auto-register SIP phones such as the 89xx and 99xx in CME 8.6?
I recently upgraded to 8.6.1 and started experiencing no voice on call blast group that forward to the remote site.Site A:Ring Call Blast at Site A, NACF to Site B (82+ext)Site B answers call and no voice.However, dialing from Site B to Site A (IP Ph...
Hi, I need some help configuring my spa3000. I need to forward all incoming calls to a voip number. I successfully forward calls, but line is incredibly disturbed and, after about 5 seconds, hangs up. Can you help me? My country (for tone configurati...
I moved a UC520 for a client and all of a sudden their VM to email notification is no longer working. All other aspects of their CUE are working fine (i.e. auto attendant, mwi, etc). I have run a debug test on the system when leaving a message and am...
Hola.A ver si alguien me puede ayudar, acabo de instalar un UC560, ya le actulaice a la versión más reciente, sin emabargo al cargar el paquete para agregar el idioma Español (México), cuando llega a la parte del Voice Mail tarda demasiado y no carga...
Hi, we have just deployed a UC320 with 14 x SPA508G handsets. The issue we have is that on internal calls, when you dial an extension, the user answers and says 'hello', but all you hear at the other end is the 'o' of hello, the call otherwise is pe...
I have a UC560 that is running 8.6.1 and we have a PRI connected as the only phone line. Our PRI provider will not let us send a caller id phone number that is not in their system so when we have a SNR call it shows up as our main number on the cell...
HI, I installed the UC320 for a customer and they have 19 users, we are using sip trunk for voice trafficit now encountered an annoying problem, The isp is doing the maintenance in recent period and their sip trunk is coming down and up occasionall...
Hi I am a newbie. my school is planning to upgrade current phone system to cisco uc560. We have 40 phones and 3 fax.I plan to replace all phones to cisco IP phones but we decide to keep fax as before. We use a T1/E1 line and were given an exten...
Looking to setup a UC560 in a manufacturing/warehouse environment and the CP7926 bar coding capabilities would be great; the product description states it works with Unified Communications Manager and not Manager-Express: http://www.cisco.com/en/US/p...
Hi,we have been advised that the VWIC3-1MFT-T1/E1 card is the one required to rpovide UK PRI (ISDN 30) connectivirty for the UC560Is this correct?Graeme
Currenlty our outbound caller ID for all users show the main number, is it possible to show the DID of the user instead of the main number?
UC560, how do i disable dhcp on vlan1 ? Due to joining customers subnet?
