Is there a way in UC560 to look at a phone's uptime? We may have an issue with phones rebooting and would like to see how long certain phones as been on.Thanks!
Hi again,Situation is:AA is setup for daytime AA for this customer. At 5pm, night service kicks in and we need to have all calls that would go to that AA automatically go to an answering service. Question is:Is it possible to make that DID or AA fo...
Or do I need to have the fones explicitly request the non-BT version of 7.4.9a?(Its just that our provisioning system is working quite happily right now, and I don't want to add Yet Another Set Of Instructions for our users on how to setup their 525g...
Please help! I am not a technical person so I will probably call everything by the wrong name, but we have cool new SPA525G phones on a UC560 thingy. We are using the Cisco Smart CallConnector Advanced client and server which has a menu and a toolb...
Hi all,Being in a bilingual country, we have a client that would need to be able to route inbound calls by area code.The client will have a T1 PRI, and would like to have something like this :Outside call 514-XXX-XXXX -> routed to AA1 (french auto at...
HiI have a problem with dialing into the uc320w on the fxo line which goes to the AA, the caller gets the option to dial the ext if they know it but if that user has his phone on divert to an external number (sip trunk) then it does not work, if i se...
Hi,does anyone of you have any experience with integrating a cellular phone, e.g. Nokia E51/52/71 or HTC Tytn II, on a UC540?It´s quite anoying clicking through all of the available clients.1. Which client is the appropriate for the phones?2. Is it p...
I now have 2 spa303's 1 new one that was previoulsy installed which do the followingsplash screenInitialzing networkChecking DNSRebootIf I push menu while on the first screen I get the menu however it reboots before I get down to 14.I have tried also...
Hi Members, I have a site with a UC540, this is an experimental site and fictious. I have setup this system in our training room and ordered its own Lines though a carrier.The ISDN is through Telstra. I have setup the Dial Plan for Australia and the ...
Hi team We are planning to install UC320W for my client and we need to bring 3 PSTN lines form a remote office and send 3 FXS extensions back to that office, we don't have any VPN tunnel in between both locations, We are planning to use NAT in router...
Can someone help.Have a customer that had a power problem and now the UC540 will not boot up.Can get into CLI and when show flash there is only one file which is UC500-advipservicesk9.......Should there not be a startup config file?How can we copy th...
We want to to route calls between 2 systems on a local lan. Each system will have their own subnets and vlans through a port on an ASA5510.Currently the multi-site wizard wants to create a vpn for this connection through the wan port, but as we use a...
Hello need help about a call back in UC500.from Internal to External Ip Phone --> UC520 -->GSM Gateway(2N voiceblue lite) OK!!from externalmy GSM number--->GSM Gateway (2N voiceblue lite) -->UC520 {cue auto attendant number } -->ip phone OK!!!...
HiA client of mine has purchased the extended 3 year service for the uc320w, what is the best way for them to contact cisco support if they have a problem. They are based in NZ.Thanks
Good morning,I am Italian and my problem is related to two Cisco SPA 303 I bought during my last trip in US and connected to my Router PBX Fritz!Box 7390, all incoming calls, locals and externals are received in the right way, while for outbound call...
