Hello,I do not fond the way to program an external number (let's say 02-12-34-56-78) to a speed dial button on a SPA500S extension of a SPA525G ?I am using v8 UC520.Could you please post CLI commands as example ?Thanks,Stephane
I'm reposting my question from XML applicaton sub-forum here: Hi, I tried to use CiscoIPPhoneDirectory XML directory and ran into a limit around 10000byte for the XML file.I used SPA504g phone and tested with FW 7.4.6, 7.4.7, 7.4.8. Only the error ma...
My ATA drops my VoIP calls after about 11.5 minutes which is very frustrating to say the least!My ISP tells me that the problem is in the ATA firmware and to upgrade to the latest firmware 5.1.10 (GWa)I am currently running 5.1.5 (GWa)I get a popup d...
HelloFor RING GROUPS, HUNT GROUPS, or CALL FORWARDIs there a way to DIAL IN, to Enable or Disable Call Forward?Presence, is the PRESENCE available on the UC320?If yes, is this a CLIENT installed on Windows and MAC?Thanks!W
Is UC300 going to support and when the following: - International dial plan - Variable length dial plan- Custom associations of dial route patterns with multiple trunksThanksAleksandar
Hi All,Does the UC320 do distinctive ringing - ie, different ringtones for external / internal calls? We have an end user who wants to be able to differentiate between calls. Any thoughts / ideas? Alan.
We have been seeing some odd behavior this morning. Three of our phones did a reboot where they said "Phone Resync in Progress"One of the reboots happened in the middle of a phone call. Have you seen this type of behavior yet?ScottCreative Computer ...
My company just bought some spa504g. The technician that sold them us, assured that they would work being powered from our Catalyst 3500 XL. Since apparently the spa504g does not work with our switch's POE, we would like to know whether we need some ...
Hello!If I save a personal number and name, is it possible to display the name of this number when it is calling me?At the moment there is only the number on display although the number is saved with a name in personal speed dial.I need it like on mo...
Hi All,As per the subject heading, if I was to put a cordless DECT phone into the FXS on the UC320, is there a way to transfer calls between other FXS based phones?Cheers,David.
Does anyone know when the next version of UC500 series software will be released? I'm assuming it will be 8.1.5 or 8.2.0 .It has been almost 5 months since the release of 8.1.0.Thanks!-BrianComputer Repair NJ
There are a few issues with the web interface for the uc300w that I wanted to ask about and possbily get a resolution.1) When logging in, if you press tab between the username and password, it goes to the address bar and you have to click on the pass...
70 entries have been loaded to external directory of SPA303 via yellow page of UC320. User can press "dir" button --> 3 (corporate directory) --> 2 (external directory) and dial the number (1~70) to make the phone call.However, the phone will be no r...
We have two clients both using the UC540 with nexVortex SIP Trunking and they are unable to call each other but can make and receive calls to anyone or anywhere else with any issues. Does anyone have any idea's on where the problem is. We have been o...
