I installed a UC520 at a customer about a month ago. They are using all SPA525G sets, including the receptionist. She has two add-on modules.Her button layout is below: Phone 1st moduleX300 (her ext...
Hi,Could anyone tell me what the maximum loop resistance for the SPA2102 is and also if it uses a ringing SLIC or a conventional SLIC?I want to connect a phone over 2km of copper (24AWG) and wanted to know if the 2102 could handle this.Thanks,Craig
I have seen the release notes for firmware version 9.0(2)SR1 for TNP phones, which can be found at http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_0_2/english/release/notes/7900_902SR1.html.The 9.0(2)SR1 and later releases on TNP phon...
Hi, first time user here of a new UC540 system, but no stranger to the CLI of Cisco. I upgraded to the newest version of IOS and CUE for the UC540 in an attempt to get the operator script for the auto attendant which drops a caller through to the op...
I've been trying to install the Office Manager 2 Beta, but keep running into the following message at 30% completion: "Error Reading Users"After 5 to 10 minutes the install eventually times out and I get the following message: "Unable to Communicate ...
Hello,I need to know if you can have multiple participants in a conference display video with the CUVA cameras and UC500? I've had a request to quote out a video conferencing solution. My background is UC500 only, and I'm having difficulty deciding i...
I was wondering if I set up a SSL VPN on UC520 on a non-default port, say 44300, where do I enter that information in on an SPA525G? Loooking into this option as as the system is currently setup the certificate presented by an internal server is thro...
Hi All,Is there a way of registering phones other auto-registration or manually adding the mac-addresses. Can you register phones on the fly by entering a registration code followed by the extension number on the phone.Steve
I have done this before where I created a vlan and then configured the IP address and then assigned that vlan to a particular port on the uc520 and then plugged my network cable into that port and everything was good. However, I have tried those same...
I have a UC560 that has an auto attendant setup to receive incoming calls to a main number. I have an after hours AA that is hit on holidays and weekends automatically. That works fine. The customer had a fire alarm the other day and had to leave ...
I have an SPA9000 with 3 VoIP lines and the 4th is connected to a PSTN line through a SPA3102. I just purchased a SPA525G phone and I would like to setup 4 of the lines on the phone to connect directly with the 4 lines on the SPA9000. That is to say...
I have some troubles with my SPA3102.I use debug level 3 and after a reboot I have the following messages:<134>System started: ip@192.168.0.3, reboot reason:H0<134>System started: ip@192.168.0.3, reboot reason:H0<143>.subnet mask:.255.255.255.0<143>....
Hi All,I'm running the latest CCA, CME on the UC500 and would like to change the Voice, Data VLAN addressing scheme post implementation. As I'm am new to the UC500 I am running scenario based labs to see what would happen.The UC500 is connected to an...
In Australia where line rental is expensive, it is common to have a 'Multiple Number' service, where the incoming ring patterns vary. (So a call to number 1 might sound like brring...brring..., but a call to number 2 might sound like brinng...brr......
