Press 0 on UC540 does not transfer calls to operator. This affects some users not all.So for some users when the voicemail comes on i press 0 and transfers to the receptionist. Others press 0 and it goes nowhere.
I need a cicso tech that can help log in to my phone system, look at the logs and tell me what is wrong. Phone support is gone now and i need help. Is this possible
When I answer a call on my bluetooth headset connected to the SPA525G2 ip phone and put the call on hold either using the hold button under the display or the "Hand" button, and then use the same buttons to resume the call, the audio always jumps ...
Hello and Thanks in advance
using spa504g phones with spa500s side car; I want to have the side-car work as per article
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=7aa7fdd7d543437ab12a3dbb0940aebe_Configure_Attendent_Console_Key_LED_Pattern_on...
Hello!
I'd like to know if there's any way to use the MWI or the extensions' leds for indicating missed calls?
The default missed call reminder is not that noticeable, needless to say if the screensaver is on, I can't see it.
Thanks!
I have a UC520 which I'm trying to configure. We are switching to a new ISP who requires that the WAN (FE 0/0) port be tagged with VLAN 35 and then the PPPOE dialer (Dialer2) connected to VLAN35. How should I go about setting this up.
Thanks!
I have been trying to upgrade my cisco spa 504g iphone firmware from 7.5.7 to 7.6.2. I have been following all the steps in the upgrade process by doing it the TFTP server. The phone seems to be upgrading, but after the process is done the phone is s...
Does anyone have suggestions for configuring a line on this 8 port ATA for faxing? I have quite a few that can either send or receive and some that won't do anything. I use 4 ports for phones and 1 port for faxing (Ricoh)......any suggestions/advic...
I have a Cisco IP Spa504G phone in our upstairs conference room. I am trying to find a way to make it possible to answer a phone call come into a different line on this phone in our conference room. Or make both lines the same.
Any ideas?
Th...
We just upgraded our internet service to 100mbps but my phone seems to be limiting my service to 25mbps. Via wireless I can get full speed but when using wired through the 525 it gets capped. I believe this has something to do with me using a Mac as ...
I have a client who strongly requests to have a "redial", "miss", and "answered" soft key on the idle screen of his SPA504g phone. I configured the psk1 option with "miss" and inputted it into the "Idle Key List" via the phone's browser. I also m...
Hi,I have a partner with the following question, they are positioning a BE6000S and they’re asking if the BE6000S supports redundancy, and if so what type of redundancy. Thanks
