Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi all,
I've come across something strange where the WAP371 will not show any neighboring 5Ghz networks, even though I know for a fact that there a quite a few around. Both 2.4Ghz and 5Ghz radios are on, but when enabling Rogue AP Detection, all I ...
I made a firmeware upgrade of my WAP150 from 1.1.0.9 to 1.1.1.0. The webiterface showed the succesful upgrade and was rebooting the device. After that, the green led was blinking for hours and AP was not available on the network. After power off and...
Hi All, I am getting high latency in my AP. Please suggest how I can reduce this. With WIFI : Ping statistics for 10.71.1.6:Packets: Sent = 46, Received = 45, Lost = 1 (2% loss),Approximate round trip times in milli-seconds:Minimum = 1ms, Maximum = 6...
Hello friends.I have several AIR-AP1852I-E-K9 and AIR-AP1562E-E-K9 administered centrally in a controller configured in one of AIR-AP1852I-E-K9. Specifically the AIR-AP1562E-E-K9 they are attached with two AIR-ANT2547VG-N antennas connected connecte...
Hello engineers .I have three APs, two WAP150 and one WAP125.WAP125 reports right client wireless types (b/g, n, a, ac).But WAP150's status screen reports only b/g or a for n,ac clients.And one of WAP150 does not reports traffic graph. 1. WAP125, it ...
I replaced my WAP371 wireless APs with 2 WAP581 APs. If I make a Wi-Fi call and roam between WAP581 I seem to get a 1 second drop. My test is I call my wife using iPhone7 and 7Plus. She is on 1 WAP581 and I am on the other WAP581. If I walk over...
Hi,We have 3 Cisco WAP561 in a cluster. It worked at the begining of the implementation.A few months ago it started having issues. The signal is good, devices can connect successfully but either no internet at all or very slow and unstable speeds. T...
- AP1 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 - AP2 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 - AP3 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 Three wireless APs suddenly go off at an unexpected time.No records ar...
Dear Community, I have a strange issue that I never seen before on my career.My WAP581 freeze entire network of my company during startup.The switch where clients and the WAP581 are connected is a NETGEAR GS748TS (a stack of 3).Model is WAP581-E-K9 V...
Hi,i ve just bought cisco wap 125 AP.Is there an option to set ip range for devices which need to be connected to ssid.every new device gets 169.254.x.x/16 ip adress. i want make 192.168.2.x/24 kind regards, Tom
Hi everybody, When I configure the CHROMECAST ULTRA in our meeting room I have the following message: "Meeting room can be configured but it is impossible to communicate with him from your Iphone A slight modification of your wifi settings is maybe H...
What are people replacing the WAP371 with? I have one in my house connected to a RV325. The WAP is failing but the RV325 is working fine. I'd like to replace the WAP with something new that will work well with my router but isn't Meraki. I'm looking ...
Hi,as described in the german quick guide, only the ethernet led is flashing quickly, seems like a bad image. Also checked with a sniffer, no traffic on the ethernet port. Thanks a lot! PID VID: WAP321-E-K9 V01 https://www.cisco.com/c/dam/en/us/td/do...
I have a couple of Cisco WAP371 wireless APs and there is an issue with Wi-Fi roaming with iPhones. My test. I called my wife in the other room. She answered on another AP using Wi-Fi calling and an iPhone7. I walked to the AP she was on and when my ...
I using nine Wap371 to setup Single Point, The 5ghz is no problem but when using notebook at 2.4ghz, it always down.How can I make it stable and faster?WiFi user around 180(include mobile phone and notebook)Please help.
