When I configure the phone in CUCM it shows an IP of .189When I do a packet capture I see the phone has an address of .190I have deleted the phone and tried a factory default but keep getting the same problemany ideas?version 7.1.3
Working on upgrading a 7942. I have tried factory resetting the phone and now all I end up with is the Cisco splash screen, and a circle with a dot in the lower left-hand corner of the phone. It doesn't do anything else...just sits. The image I am ...
Does anyone know a way to turn on security on switch port to force it to inform the port to only allow assign a voice IP address to a Cisco IP phone and if it's a PC then it will only get a data IP address. Basically we don't want a user spoofing his...
If I add an FXS card into a 3845 voice router, are there any DSP consideration?
We have recently upgraded our phone system from CM 4.2(3) to 7.1(3a). The upgraded system is working well, but users have found that when they reboot their phones or login or out of Extension Mobility (and therefore reset the phones), an error messag...
I need to setup a 7911 IP Phone by our front door so when the reception is out and the front door is locked visitors can pick up the phone and dial one of two extensions to reach somebody to let them in. Is this possible? I am using Call Manager 6.0....
Is there a way to use <number> AbbrDial with CME 7.1 ? I notice the phones have a Softkey for AbbrDial, but where/how does it get programmed? A search of the CME Administration Guide.pdf for AbbrDial gets no results. I did find in http://routerip/ccm...
Dear all,When any IP phone user forword all his calls to his mobile he just press CFwdALL button and type his mobile number from phone set.If this user has CSS with a code, no call forword will be done, and if i adjust it for him from CCM interface t...
I have a two server call manager cluster. I have my router with PRI setup with two dialpeer's, the first one sends calls to the publisher and the second one sends calls to the subscriber.This morning we took the publisher down to test failover to th...
Hi All;How can I debug (to see if the call coming) to the voice gateway at its E1, but it has 5 E1s? Actually what I need to do is to know if an incoming call to the number 23451518 (DID is 1518) was reached or not?When we try to call from any PSTN o...
I have create a route group to include two H.323 gateway (3845 router) for redundancy.The CUCM version is 5.1.G1 and G2 added in the route group with "TopDown" distribution algorithm. When i dial outgoing call, it would go through the G1.I have perfo...
Using CM 6.1.2 I have a 7921 phone and 7945 phone configured to use the same static phone number.The phones both ring when someone rings the associated extension number, trouble is when the call is answered on the 7945 phone the 7921 continues to rin...
Hi, I have 2821 CME at remote location and Cisco UCM at Main location. I need dial peer/SIP trunking over MPLS WAN connection configuration example for this.. DO any have it? Please suggest any related soultion or exmaple link.ThanksSandip
Hi team,I have configured CUCM 6 for vmprofile(voice mail pilot 9000) and associate with ip phone.(configured, Vmail ports(6), line group, hunt list, hunt pilot, voicemail pilot and voice mail profile)On unity connection 6, under telephony integratio...
Hi , I have IP communicator client version 7.0 installed on Laptop.And CUCM 7.0 in the setup. Communicator does not show extension on line button .It displays only time and Date.However it is showing registered in CUCM. Can anybody please help....
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
3 | |
2 | |
1 |
