IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Resolved! AA in CCME
hi,i'm using ccme 7.0 and cisco unity express, i have configured voicemail and it works fine.now i need to use AA, what i need to do?i shud use B-ACD, or just the script aa.aef.please help
bsaid1977 by Level 1
  • 634 Views
  • 7 replies
Calls are extablishing fine between the Nortel and CUCM users over ISDN E1 PRI and vise versa.However When the IP Phone calls the PBX Phone the PBX phone rings fine and the call is established but you cannot hear the PBX phone ringing through your IP...
I am having problems with the call park feature disconnecting once the person has been parked. The system will hold the call for around 30 seconds and hang up. We have a 2811 Router with CME installed and it is running version 12.4 (4) T2. We had a...
Cougars22 by Level 1
  • 1138 Views
  • 3 replies
I have two 7961's that I have set up Busy Lamp Fields on their phones. When one of the extensions that is in the BLF is off hook the red light does not light up on their phone. I have this set up on other phones in call manager and thought I had dupl...
Mojo1 by Level 1
  • 1585 Views
  • 2 replies
I've got a 3845 on IOS 12.4(20)T3 and there are two dial-peers configured as follows.dial-peer voice 80000 voip description Intersite Dialing via ITS-UCM02-PP destination-pattern 001.... progress_ind alert enable 8 progress_ind progress enable 8 prog...
rcblack by Level 1
  • 325 Views
  • 1 replies
When a user gets a call on the cisco phone and the user transfers the caller to another phone voicemail, he presses transfer *1 and the users extension But by the time the user presses the finaly transfer the greeting as ended it does not restart. Is...
ggittins by Level 1
  • 945 Views
  • 4 replies
Resolved! Route pattern help
We opened an office in Shanghai and I am trying to set up a route plan so they can dial 800#'s correctly. The issue is I am not sure how they would normally call a toll free # (aka 9.01[800]XXX XXXXSo I have an end user there who said she can normall...
nixon1234 by Level 1
  • 380 Views
  • 1 replies
