Is there any way to force a phone to register with the "Standby" call manager? I can't think of a way, but I thought someone on the forum may have run into this before and know a method to make it happen. Thanks!Steve
One of my user lost his Attendant Console Speed Dials. Is it possible to restore the ACXmlData from a BARS backup? And if yes, where is it store?
All,Is there any way to remove the personal address book as a menu item under directories on a 7911 phone? (or any other for that matter!)Thanks in advance!
Hi all, our bussines asked us for some call accounting statistics (src,dst number,time,call lenght,and so on). Do somebody have hint, how to arrange these statistics on cisco voice gateways and gatekeepers? Can they be sent to syslog servers? We got ...
Hi there is an ISP providing the CCM services, and i would like to ask if we can host some services by using CCM or CCM express. Whats the best choice. And the CCM version is it important using front and back end or doesnt matter.And something else.C...
How I can do this without web page Admin Bulk Administration.I want to do this with SOAP?Can you provide me the plan how I can do this?What I should use?Please try to write your opinionThank you
I recently added a 7936 station to my UC500 installation. When I booted up the 7936 it downloaded new firmware then picked up an extension and can make and receive calls normally. However the strange thing is that the conference button only works t...
Hi All,I experienced problem with E1 R2, I configured it,the problem is:If I called a destination(mobile number) that has ring back tone(music ring back) the call failed, but if hasn't the call success .There is a problem in dealing with music ring...
I have SRST router , i need once incoming calls reach to FXO ports , ring group of extension at same time , it is like hunt group in call manager but i need the steps in SRST router configuration thanks
Quick questions chaps.I have CM 4.1 cluster with 5 sites, all site to site traffic break out at PSTN - no calls pass over the WAN. When I use extension mobility for user a at site a and got to site b and log into the phone (taking my number) when I p...
Hi,Currenlty we are running with UCM version 4.3 and the directory is integrated with Win 2K3, now customer is planning to migrate their directory to Windows 2008.Just wanted to know whether this would be supported or not.Kindly advise.
I have a client using CUCM 4.1.3 SR2. The cluster has a PUB, SUB1, SUB2.They have EM configured with the EM Service URL pointing to SUB2.But the EM service is not activated in both the SUB, its running only on the PUB. EM works all fine, user is able...
Hi, I am sure the answer is probably No, but does anyone know if it is possible to rerun the IPMA Wizard within CUCM7?I am happy to configure manually, but if this is possible it would be good to know.Many thanksSteve
I have an FXO port for a 1MB line on an H.323 gateway which forwards calls to a CUCM 6.0 server.FXO Config:voice-port 0/2/0 echo-cancel coverage 64 timing hookflash-out 50 connection plar 4488 description LINE FIVE caller-id enable Dial-peer config:d...
Hi guys,I have a customer who wants a prompt to be played saying " we are sorry we cannot connect your call please dial xxxx" during SRST mode.I believe all I need to d is to record the prompt and place in router flash and then reference it in my pa...
Subject | Author | Posted |
07-14-2025 11:42 AM | ||
07-14-2025 08:15 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
