IP Telephony and Phones
Labels
Hi,Our client requires following feature in IPMA,- If someone leaves voicemail to manager phone, assistant phone should receive some sort of notification. But MWI should only turn on if assistant receives voicemail.Kindly let us know whether this is ...
Dear alli Have fxo port on my voice gatewayi define connection plar on my FXO voice-port.and also defined sutable dial-peer to route the connection plar into CCM.but when I dial the number i hear just fastbusy!i debuged and saw theat the connection p...
miskoolak by Level 1
  • 441 Views
  • 6 replies
Running CM Version 5.1.1.2000-2 .... not able to get any CDR records since Dec. 28th. Getting a 10021 Error: There are no matching Records. Not sure where to look - been working fine until then.
Hi everybody,I'm configuring hunt groups in a CCM 4.3 (2) and it works fine (I think so). The problem is that I'd like to make the call remains ringing in the same group, even though there's no answer, until someone in the hunt group could be availab...
I've read that while an RJ45 will work, an RJ48C should be used for a PRI coming from smart jack into a Cisco vwic. Today a customer has the PRI connected to a pbx. I looked at the face plate and I can't tell if it's an rj48 or rj45. Their cabling...
Hi,CUCM 6.1 with H.323 voice gateway configured for mobile voice access features. On the gateway, I configured the following service application: service cmm http://172.17.0.15:8080/cmmivr/pages/IVRMainpage.vxmlWhere 172.17.0.15 is the publisher CUCM...
jjia by Level 2
  • 806 Views
  • 3 replies
