IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5959 Views
  • 14 replies
Hi,I have a Unified Call Manager 4.2 and a Jtapi user created to 'connect' CCM environment to a CallCenter software. I am heaving problems with some routing points. When I make a call to an RP it takes around 10 seconds for the RP to respond and some...
mc12mc12m by Level 1
  • 467 Views
  • 1 replies
It all started out with not be able to receive faxes, but I can not even "call" the FXS ports. I have connected (for troubleshooting) a regular analog phone which (same as the fax) can call out, but it does this with a anonymous number. If I call the...
I have a 7970 phone that is not ringing it flahes but does not ring.I am running CME 4.1. When you put it on a speaker you don't hear dial tone. Even if you add other extension on the other lines the phone does not ring. I checked the settings on t...
We've get the problem in fxo port that user get silence tone when make outgoing call in this port. When I use RTMT to monitor it, I find the port status is busy. Also, I enter "sh voice port sum | inc fxo" and find this port is up and off-hook. I've ...
mike.lo by Level 1
  • 551 Views
  • 1 replies
Resolved! VG248 swap out
What do I need to do to swap out a VG248?I conigures the IP address etc.., enabled the portsDo I just configure the GW MAC address in CM and/or do I need to go into each DN and change the MAC as well?Thanks,Randall
rcrumm_2 by Level 2
  • 569 Views
  • 4 replies
HiIs this a vaild SIP failover configuration? Customer reporting that that it is not working when they take the primary offline.dial-peer voice 10001 voippreference 1destination-pattern 105session protocol sipv2session target ipv4:10.1.1.1dtmf-relay ...
msaleh by Level 1
  • 484 Views
  • 3 replies
