hi all,i see some features in Device phone page , but i can not understand what is the point of it, like:- Wideband Headset UI Control- Wideband Headset- Allow EnergyWise Overrides- Revert to All Calls- Enable Audible Alert
The content you are looking for has been archived. View related content below.
Have a pair of Nexus 9300s in vPC with vxlan evpn stretched vlans over to a pair of Nexus 9200s. I’d like to add two L2 vlans to the fabric.I’ve added the vlans and given them vnis I know I need to add them under the nve interface I know I need to ad...
I am trying to change a SIP header on an Expressway. We are sending audio out an Expressway C/E pair to a phone carrier.(this method was chosen since they already have Expressways but no Cube routers). The carrier is seeing something they don’t like....
Hello ,We want to create a spesific alarm if any calls fails with 503 or 404 error code . Is there any solution on RTMT or any other solutions ?Can we create any alarm like "this call failed with error code 404 or 503 etc."Best Regards
Hello,I've a customer that needs the above announcement before sending the call to the DDI numbers. The extensions are being recorded by Witness Systems.They only have CallManager and Unity. I was looking at doing this in Unity by sending call to a c...
Hello all. When logging into CUCM 14 on CLI, I received: your password has expired please create a new password. Ok, no problem. Go through the process entering old password and creating new password. Response: Invalid old password. Alright, try a co...
Hi the expressway's server certificate has been expired last week.when trying to access the expressway's webpage to upload the new certificate ,the browser certificate error shows, and if im hitting the advanced button in order to continue, the page ...
HiWe are getting continuously the RTMT alerts as Recording Call Setup failed for both the jabber and Desk-phone devices. Recording Option is ACD enabled, BIB is ON on the devices,Recording profile is selected, recording media sources is Gateway Prefe...
I have an on-premise CUCM and would like to integrate it with Webex, but not with Webex Cloud. Our goal is to use Webex as a softphone, allowing us to decommission our IP phones. We plan to utilize Enhanced and Professional licenses. Could you guide ...
Is https://connectthedots.cisco.com a Cisco site, or are they a third-party?
Hello Expert, Is it possible to install an antivirus on cisco cucm, CUC, CCX, IMP?
I’m having trouble with phone queries in Cisco Emergency Responder not loading correctly. The issue seems to be related to my internet router, since other online services are working fine. Are there any specific router settings or configurations that...
Listen here: S11|E17 Crystal Clear Audio for Every Call & Meeting with Webex AI Codec Hearing and being heard is essential in effective collaboration, but with today’s distributed, hybrid workforce, challenges like background noise and network disrup...
Info: Unity 3.x, Windows 2000 server sp2, exchange 5.5, Unity and Lightning fax are on seperate servers.<br><br>Are there any ramifications in shutting down our lightning fax server connected with Unity?<br><br>Basically what we need to do is upgrade...
We upgraded Unity Connection from version 12.5.1.17900-31 to 15.0.1.11900-14 using the Data Export method.Everything seemed to go without issue, but it broke the connection to a couple TIMG’s.I know the TIMG’s are end of life/support.The issue is tha...
Subject | Author | Posted |
09-19-2024 05:56 AM | ||
08-23-2024 11:56 PM | ||
08-21-2024 05:48 AM | ||
07-17-2024 05:55 AM | ||
07-15-2024 12:39 PM |
