Hi Experts,Today when I am learning our company's routers configuration, I found that a Port-channel is in L3 and it is in VLAN490 as below:interface Port-channel1.490 description To_CP01 encapsulation dot1Q 490 ip flow monitor NETFLOW_MON input ...
The content you are looking for has been archived. View related content below.
Hi.I have one Cisco ISR 4321. This is a brand new router and I am the first owner.I have encountered the following fault since the first start up:It keeps restarting at random intervals. Sometimes after 10 minutes but sometimes it lasts for 2 hours.T...
Hi,we are using the Cisco ASR1001-X as core router on our ISP network. For the management of the CPE I set up a TR-069 ACS server. For testing purposes I configured the ACS URL manually on the CPE, which works fine.However I'd like our ASR to pass th...
I tried ctrl + Crommon 1> confreg 0x2142rommon 2> resetbut he didn't accept the reset the i restart the router with power button then i found router suck in below could any one help me how to solve this issue i restaert the router 2 time using powe...
From where to download the cisco images (Router and L2,L3 switches) for eve ng and which image will work good.Below is the list mentioned in eve ng but what is the proper way to download these imagesDynamips (Cisco IOS emulation)c7200-adventerprisek9...
I have a setup in which i have 2 routers connected to same ISP A both via default route pointing towards ISP for internet.Now we want to add another ISP B on both routers however that ISP will use BGP with RIPE IP address over the internet.Now we wan...
Hello Everyone I have to set up an ipsec tunnel with Lo0 as source of tha tunnel. Nat is activated in My CE and in the ISP level (NAT444)All ipsec and Nat configuration is ok but, and as I know that for the NAT to work correctly, the packet should pa...
Hello Team,I have a topology as below;I have point to point connections to multiple partners who have different unique prefixes - to avoid overlapping of subnets.They need to access my internal resources - in this case vlan 50 and 70 for respective s...
Please refer the below topology,Client >>> Cisco router >>> Firewall >>> Upstream device >>> serverI have set mtu as 200 in my upstream device and as exepected when client access the server(http) the packets are fragmented.However when I set tcp-ms...
I tested the ASA 5520 iperf3 to check its performance. I then wanted to add NAT to it to find out how much it was taxing the device. However, I kept having the problem that almost all traffic was untranslated.The created objects are the same, i.e. 19...
This is very high level, wanting to know if this is possible. We're the middle man. I don't have access to or knowledge of equipment or configs on the other providers. Currently we are handed off a GRE tunnel to a router. We have an ipsec tunnel ...
Hello,I am doing a lab for class that's due at midnight tonight and I've been having trouble for the past couple of days. The assignment is to essentially create a topology with 4 different networks connected with 3 different routers. 3 of the networ...
Hi,I have upgraded my Cisco Nexus C93180YC-FX yesterday from NXOS 10.2(6)M to NXOS 10.3(4a)M, but I seem that I have an error when I make "sh logging last 10".2024 Apr 30 09:39:09 edge01.par03 %DAEMON-3-SYSTEM_MSG: error: Unable to open the btmp file...
Hello,We have run into a situation where we need to load balance internet traffic outbound i.e. for wired subnets we want to send traffic via ISP A and for Wireless users we want to send traffic via ISP B.I am pasting high-level branch infra picture ...
Hello,I am on FTD2130.I have configured various interfaces with their respective subnets and they are advertised successfully over OSPF.I want to advertise over OSPF a subnet which includes public addresses to be used as NAT gateways (for various pri...
Subject | Author | Posted |
08-07-2024 10:40 AM | ||
07-15-2024 05:07 AM | ||
07-13-2024 09:04 AM | ||
07-09-2024 05:41 AM | ||
07-03-2024 08:54 PM |
User | Count |
10 | |
8 | |
7 | |
4 | |
3 |
