Routing
“Webinar
Labels
Introduction: This document gives information about DMVPN with a configuration example.   What is DMVPN?   DMVPN stands for Dynamic Multipoint VPN and it is an effective solution for dynamic secure overlay networks. In short, DMVPN is combination of ...
naveenal_0-1726756011765.png naveenal_1-1726756011789.png naveenal_2-1726756011791.png naveenal_3-1726756011793.png
Please refer the below topology,Client >>> Cisco router >>> Firewall  >>> Upstream device >>> serverI have set mtu as 200 in my upstream device  and as exepected when client access the server(http) the packets are fragmented.However when I set tcp-ms...
RobotAjay by Level 1
  • 58 Views
  • 0 replies
Hello,i have an ISR 4431 Router with broken flash. The device has been registered with Cisco but i have no additional contract.According to the chat support, there is no way to download again the IOS delivered with the router?Any idea how to do this?...
wh17 by Level 1
  • 181 Views
  • 8 replies
Hi The DMVPN tunnel was reset, which caused the BGP session to reset as well. We observed that the DMVPN crypto socket is down. What could be the issue? We suspect it might be related to the ISP, but they have reported no abnormalities in their logsD...
I have a Catalyst 2960-X model switch with the port 3 and 4 led blinking green ( communicating ) and suddenly starts blinking orange for a few moments and then flashes green normally. It's been swinging all day. Thank you
Translator by Community Manager
  • 101 Views
  • 2 replies
in the shown design , why the PC connected to R1 can't ping to the last PC , while R1 can ping to the last PCnote : The PC connected to R1 already configure the default gateway R1
I have a Cisco 2951 router, and I switched the domain name from localdomain to 'mydomain.us'The few local hosts I have, I resolve on the router, while hosts outside my domain I forward.  It looks like this:ip domain name mydomain.usip host seismo.myd...
roncro by Level 3
  • 231 Views
  • 8 replies
ASR 9904 using DC V2 power supply its major alarm persist after turn on power supply , it’s disappear only after remove and re-insert the power module, can anyone know the cause?
Unanswered Topics
