I have started the upgrade of CSPC from version 2.6.1 to 2.8. The furthest I got was putting in the command /opt/LCM/bin/lcmagent-apply.tcl JeOS /home/collectorlogin/<jeos patch> on the installation of the JeOS_Patch_To_Enable_ASD.zip. Now I am unabl...
Hi:
I upgrade CSCP to version version 2.8.0.1, but each time enter at SNTC portal, appear the attach alert. That is okay? or how to remove this alert?
thanks.
Best Regards.
For whatever reason, it would seem the below thread is considered closed:https://community.cisco.com/t5/smart-net-total-care-portal-and/missing-data-with-latest-uploads/m-p/3748055and CSCvn48271 is being considered fixed. Per the request at the end ...
Pulling a custom inventory report for a customer and it's showing 2 collection dates, one in June and then the latest one. I have the report preferences set to only show latest, not comprehensive. I do not believe I've even see this before with any...
CSPC 2.8 in-product help and its manual do not state the full path for the seed files. From my investigation, it seems these files should be placed at /opt/cisco/ss/adminshell/applications/CSPC/data
However, when i try to access this directory th...
In the alerts tab, I can not change any of the conditions of the alerts status (when i select Actions tab - "Select a Row" or "Select 2 or more rows to", I can not select anything inside them). i need help with this problem, thanks
I have a customer who needs assistance with the following 2 queries.
Query for serial number to instance ID mapping.
And then to leverage the SN2Info API once the instance ID is known
Can someone help?
David
Having same issue as https://community.cisco.com/t5/smart-net-total-care-portal-and/upgrade-to-cspc-2-8-stuck-on-quot-apply-in-progress-quot/m-p/3736801#M9330
but my output from /opt/LCM/tmp
# ls -alrthtotal 2.9G-rw-r--r--. 1 casuser casusers 1.9G ...
Hi Experts,
So, Managed nodes = Live Nodes + Unreachable Nodes
I would like to get more information on Unreachable nodes. What are they ?
I did exported all the unreachable nodes and ran a ping sweep on them. Some of them responded to the pin...
I discovered the Controller by the virtual IP of the cluster. And then the controller is not showing up in CSPC.
for details, the controller is a virtual one, with 2 nodes. I already configure the snmp access.
Julien Dymon
