Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2910 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4491 Views
  • 1 replies
  • 16 Helpful votes
Can I use the SG300-10MPP on a lager layer 2 network ( lager than class C).  I have layer 2 switch with vlan1 ip is 141.225.215.224/22 and default-gateway is 141.225.212.1 and with this config I am unable communicate with switch or switch can't commu...
cwangskr by Level 1
  • 756 Views
  • 2 replies
Hello I need help with configuration of me new cisco switch SG500-28, i want to split me switch on 2 VLANS. Default vlan and second for managament of ups,serwers. SG500-28 is conected to me network by one of ours old switch SG200-26.Then i switched m...
Hi,I need to buy an entry level switch with the following features:qos configurationsecurity features like port security, ACLs, NAC, IBNSlayer 3 featuresetmay or may not be modularat least 24 portsat least 6 POE portsPlease suggest the low cost model...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
