Salve, vorrei sapere come configurare l'apparecchio spa3102 con un telefono voip snom 300, in particolare vorrei utilizzare il telefono voip per effettuare telefonate sulla linea analogia attraverso il telefono voip snom300GrazieSergio
Hi, I try to upgrade the firmware of a spa301 to 7.5.5, everything goes fine but when the phone restart the light goes orange and nothing happen after. I try the recovery firmware with the serial number but doesn't work. I can't do anything with the ...
Our telco (Virgin Media Business, UK) have asked for some information about the PBX (UC540) in order to correctly configure ISDN PRI (E1 - ISDN30) at their end. We have a VWIC2-1MFT-T1/E1 voice interface card installed in the UC.Specifically they wan...
Cisco, please let us have one last set of new fetures and bug fixes even through you ave announced end of life. You have replied to so many posts saying that you are working on new firmware over the last year, but we have not seen anything yet.Can s...
Hi, I have a few SPA 8000 and SPA112 TA's, and everything's OK, until I tried to transfer a call from one of this analog lines, it doesn't work.For what I've saw on some info on the web, it's about configuration, but doesn't seems to work. I'm locate...
Hello everyone!I am having some issues with my UC560, when I try to call to the voicemail (499) and AA (500) it just has busy toneFrom the CCA i run a diagnostic and i recived the error messages attachedI just dont know what is happening. I already c...
I have a UC540 with the main line going to a hunt group but when the lines in the list on the hunt group are already on a call the line goes to voicemail without ringing. Is there a way to set it to ring even when the lines are busy? It is a logest-i...
Maybe I'm wrong on this one but you can't connect a UC560 directly to an amp (Bogen) without some kind of paging attendant device, correct? One job we did, the customer already had an "AT&T Page Pal" which connected to the UC560 via an FXS port and ...
Hellowe have installed Callmanager 9.1 on a BE6000 and, by misstake, we configured 8 analogic devices with no licenses purchased for them. The system returned a warning saying that we had 60 days trial period for those devices. That 60 days trial per...
Hi I’m trying to get a solution and not sure if this will work, i have called over dozen of cisco partners in my area and no one seems to know, chat with cisco produced 0 results as wellI have 4 regular analog landlines in headquartersI have 2 satell...
Hello,Do you know which methods the IP Phones use to get configured in order to work on a particular Vlan? (For example via CDP protocol)And also if the phone receives VLAN settings from multiple methods, then which is the priority that the phone fol...
Customer has an issue where 10 digits dialing to a certain number doesn't work. The number does not require a 1 or 0. When you dial the area code + the number the called digits stop at the first seven. I've included a snippet of my dialing peers. ...
