Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hello all,I have been having a tough time getting this these two to work together. It is a web-based application, basically you give them your list of DID's and allow certain ports to be open, forward your main number to them, and it is supposed to w...
Multiple times in the last week I have had to reboot phones in the network due to a hard lock (menu keys do nothing, etc)They are running 7.5.4. I have noticed a firmware upgrade is available and plan to do so, but don't want to guess at the source o...
Hi, I am hoping you guys can help me with this. I have a new customer that has an older UC520. They have around 30 voicemail boxes setup, and a few "General Delivery" Mailboxes.On one of the general delivery mailboxes(Their most important one) the en...
Hi All,i am facing strange problem, only one time caller id appears and  next time it always shows UNKNOWN Number ??I try with a normal phone and the telco is  sending the caller information.i am using UC540: "flash:uc500-advipservicesk9-mz.151-4.M5"...
I have a customer with a UC320W with latest firmware. We are having the issue in which incoming calls, which are originally routed to a hunt group, are avoiding the ammount of seconds it must ring before going to our AA. The only way to resolve this ...
We need to migrate from a CUCM 4.1 to a UC560.If memory servers, CUCM is the older Windows based version of CUCM.Are there any tools of methods I can use to pull a readable config dump from a CUCM 4.1 to serve as basis for the config of the UC500?I'm...
I am learning VoIP and am going to set one up at my house for experience training but need some advice since I am getting some conflicting information.I read that all you need for a basic VoIP setup, (not Unified,) is an IP Phone like the one I purch...
Dear all,I have a question concerning Cisco BE6000 licensing. I'ts clear that MD server support 1000 users and 1200 devices.In this case, Can I add additional phones from UPM or CUCM without being associated to a user ? Means,that I can have 200 addi...
We have a customer that uses the forward message option in CUE quite a bit. They want to have the system use extensions for the addressing by default instead of having to spell names. They are already aware of the ## option to switch to extension add...
Hello,I have a customers which have two Cisco UC560/540.The both site are link with VPN IPSec (not with Cisco UC).They can see together with private IP.The Voice subnet are the same (10.1.1.0).How can I do for link both system and than user can dial ...
