Hi,I know there are call connectors for dynamics and Salesforce, but is there any plans to for a connector to Act! by Sage.Many small business use Sage software for Accounts and CRM?John
Customer has a PRI with 12 channels. When originally setup, ISP said they would be sending four digits. Could not get it to work. Called Cisco Small business support and noticed that they were actually sending 8 digits. Ex phone number is 888-8888. I...
We are evaluating using the SPA525G phone with a hosted VOIPprovidor and in trying out the wi-fi capability of the 525; the phone would disconnect from the access point after each call and wi-fi had to manually be re-enabled for it to reconnect.This ...
Hello all,We have an SPA3102 setup connected to 3CX server and we are using the 3CX softphones. All internal call are crisp and clear with no echo. However, outside calls are not so good. We can hear an echo of what we say (delayed about 1/2 second) ...
Greetings. I have an SPA8800 with 4 FXO trunks, I want to know how to activate each trunk so the call goes out respectively, basically the first 2 trunks go to one PSTN c.o for regional calls and the other 2 trunks to a different provider for ...
Could anyone tell me how the SPA500 speakerphone compares to the 524 speakerphone? Most people complained about the 524 speakerphone. I put a 7960 in which they were happy with but now they are having some other issues so I need to replace it.
I have a UC 560 and wil like to know, how I can configure one of my FXO ports for fax services. This port is connected to a GSM gateway that has an equal amount of Sim Cards each having an assigned number.Please assist.
Hi All,I have a UC540 setup that has a requirement to have an SSL VPN configured.The SSL VPN appears to be running okay, but when a PC tries to authenticate against the website or via AnyConnect VPN I get the following "'A certificate problem has bee...
Hi,I have just got a UC520 to be configured for one of my customers. When I went to the security option under CCA, I could not find the options for SSL-VPN under securiy tab. Can anyone confirm whether I have upgrade any software to get this SSL-VPN ...
Dear all,We are using some IP Phones SPA922 in our office, and i am trying to register a registered Telephone second time through web-access internet explorer, it is accepting the newly registered name and extension number, after few minutes it reboo...
We're ooking for documentation on the formats of music the SPA series of telephones will work with. Is it possible to use a shoutcast/icecast source for the audio? Is there a standardized syntax that would correlate with the technology used?
We have a UC520W-8U-4FXO-K9 in our main office and are opening a small satellite office. Two phones are needed in the satellite office and we want them to utilize the UC520W in the main office. Which Cisco product is recommended to enable two Cisco I...
