Does any one know when the DECT handsets are going to be released?
Hi,I would like to change the Display name of UnityConnection user : "Unity Connection Messaging System" and the language of this user. And when i tried to change it, i got the error message : "Object is read only."Thank's youLouis
Hi All,During testing of a new installed Cisco IP telephony system we found that calls from analog phones, which is transfered to PSTN from local IP phone, fail.Network topology is depicted below:CUCM -- h.323 -- Voice GW (2821) -- SIP (PSTN) | ...
In reviewing the CUCM SW Compatibility Matrix for CUCM 8.6(1) [http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf], I see conflicting information for some applications. For instance, for CER, it points me to the "Cisco Unified...
Hello Everyone,so if I understand this model correctly Call Manager and Unity Connection no longer charge for the server licenses, ports, etc. Now we can install the server for free (relatively speaking) and just pay for User Licensing. If this is c...
I have an audio file loaded to the routers and are finding certain locations where the MOH skips and keep repeating at the same spot. I have removed the wave file and reloaded and is still occuring. Any idea of what else could be causing this? Below ...
We had a weird issue crop up where UC is disconnecting users while they are listening to their voicemail. If they are persistent, they can retry and eventually get it to let them listen to them, but it's becoming frustrating for them. Looking for i...
I'm planning a bridged upgrade from version 7.1.3 on MCS7845 hardware to 8.6.2 on UCS hardware (esxi 5). My MCS7845 hardware is supported for bridged upgrade to 8.6 version. Currently, all of my mgcp gateways and tftp services are pointed to the ip a...
Hello All,I just want to ask something. I do not know if any of this is possible:Let's assuming there are two IP Phones A and B. If Phone A calls Phone B1. Is it possible to customise the ringback tone that caller A hears while Phone B is ringing? If...
Hello, Has anyone had any 6901 phones with firmware 9.0(2) not go into the voice vlan and go into the data one? Problem seems to be fixed in once they are at 9.1(1) but ofcourse Cisco seem to be shipping them with 9.0(2). The only way we can get th...
Hi thereWe have CUCM 8.03 with 2911 voice gateway. We are connectet with 4 BRI's to the PSTN. I think, this is a bit undersized for 30 employees. The voice gateway is operated by our provider, i have only SNMP-read-access.Is there a way, to figure ou...
Hello All,I have been working on to send CDR data from Cisco Call Manager Express (CME) to an FTP Server but it doesn't send it. I can manually copy the files to the same FTP server via the same username/password. You can find below some configuratio...
Hello,we are running now cucm 8.6.2a as a vm. I wanted to save the configuration via export config/ job sheduler. as a result there is a .tar file listed under the completed job. But when I try to download the document all I get is a popup window lis...
Hi to all,We want to migrate a client that has a cluster CUCM 6.1.5 with 4 78XX servers ( 1 PUB and 3 SUB ) to UCS 8.6.2.I have some doubts about it:- The actual hardware does not support the CUCM 8.6.2 to make the backup and restore in the UCS Blade...
Hi,I have installed unity connection (v7.0) and integrated with active directory, and callmanager (v7.0) integrated with active directory and created user device profile for all users and having +e164 numbers for the extension. In unity connection i ...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
