Is there a way to remotely connect to an IP phone and change its speed duplex?The phone is alreayd registered to a CME.
We have unity connections version 7.X which we upgraded from 1.2 over the weekend. I am woundering if we want to turn on LDAP integration on the connections server will it delete the users we already have in the system like call manager will. Also,...
Hi all,I have a few numbers that are part of our Corprate DDI range that are handled exclusivley by our Telco at Carrier level. These numbers divert to an 0800 number and allow numerous Time of Day routing options and messages to be played.I want to...
When placing a call I am getting a second dial tone. It seems that as soon as the route pattern is matched sending it through a 2801 MGCP gateway I get the second dial tone. Call Manager Business EditionSystem version: 6.1.2.1000-13Any ideas?Thanks,R...
Hello everybodyI have a problem with my cube implementarion. I have cube with inside leg with h323 (CCM 4.1) and a outside leg with SIP. The problem: when a I receive a SIP INVITE req to a new call, after sending 180 Ringing to the remote peer, the G...
To fake_display shows up on screen on some outside calls. I have users who are dialing some 888 numbers and since I upgraded to 5.1.3-5000 they will get thisappearing on their screen....âTo fake_Display 18883740234âDoesn't affect the call, but I...
We are having some FXO disconnect problems at a site in Shanghai China. Does anyone have any experience with a CME install in this region using CNC (China Telecom) as a provider? The system works fine for a few weeks and then randomly get two of the ...
Hi,The problem I have is users log in to CCMUser ok but any of the options they click on give HTTP 500.They are in the Standard CCM End Users group.I've restarted Tomcat on both the subscriber and publisher.All the other functions which require web a...
Hi all,Is there any incompatibility in CDR format between versions CCM 5.x and CCM 7.x?I have billing software developed for the CCM 5.1, and it's quite important to me to know would it be necessary to hire a programmer to change/modify my software f...
Hi All,I have this Problem with a CCM 4.2 I am working on.It looks like it has all the files to support the software/firmware for the New Phones including Cisco 7921G.However when I try to add the Cisco 7921G Ip phones in to the system it doesn't sh...
how can I set up a simulated pstn connection via a back to back e1 a Catalyst 6509 E1 module ?thanks
How can I make my phonenumber get connected to the voicemail when I quit for the day when I have a transferring of my number to my secretary? Is it possible to make the phone transferred to the voicemail in the end of the day? And then configure it b...
Hi experts,We just upgraded the firmware of our 7941s. All are good except one. It doesn't upgrade at all. I factory reset it by holding #, 123456789*0#.After this, it's still not fixed. Then I directly connected it to a laptop as TFTP server with SE...
I know some of you already have solved this. I have a phone proxy working but have issue on getting the extension mobility working. It displays the extension mobility on the services button but when clicked, there's no login/logoff only "http error"....
Hi,I just wonder how to set up RAID as Mirror on a call manager 7 server? When I build the server, it doesnt really have option to select the RAID.it seems that there is active partition and inactive partition that you can switch the version ... howe...
| Subject | Author | Posted |
| 12-13-2025 06:42 AM | ||
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
| User | Count |
| 4 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
