HiIs CCME 7 support parallel Hunt for sccp phones??
I have a T1 CAS that needs E&M-Immediate-Start hence the H323. Can someone look over my config as I cannot make or receive calls.
Is it posible to define several number ports in voice register global? I have already register a SIP trunk with a SIP provier but I can't make calls.The provider told I need to open UDP an TCP port from 5060 to 5090.In the option "voice register glo...
I have a phone, that when the hand set is picked up, I want to automatically dial an extension. This phone will only be used to dial this extension when the hand set is picked up. We are running Call Manager 6.1. Is this possible, and if so, how d...
i have a cme version 3.3, running in a 3640 router, with the lastest ios, with 128 ram and 32 flash, and i want to upgrade the cme to 4.0 or later if it is possible, but the flash is too small, so i installed two compact flash each one of 16M, i woul...
Hello,We're running call manager 4.3 and we have a cisco ip conference station cp-7935. What is the maximum amount of partipants/connections it can support at 1 time?
Hi all, Please help me to customise the background image for the cisco ip phone series 7971,7961,7945 phones. Nahas
Since we have to prepare for the migration of our traditional PBX to an VoIP infrastructure we just started gathering basic knowledge on VoIP communication principles and product specific features. Since we do not have access to an test environment w...
I have two publisher from two different cluster. And now I want to change one of the publisher to be the subscriber of the other one.... can that be done without rebuilding it? Its for call manager 6.1.2. thanks
Hey all, we have a 7975 with a 7916 module. We upgraded our CM 5.1 code to support the module and it see's it, we select it on the device.The expansion module shows numbers from 1-14 for SD but if you enter anything after SD 14 it's called "abriviat...
Hello Sirs,I want to ask some question about DID;1- Is DID idea is the PSTN will send last 4 or 5 numbers from the full format number like that 33401234 is the pstn will send to me 1234.or2-this service will force the PSTN to send the called number a...
hi guysdose cisco IP phone can disable the pc port automatically when it detects a loopback on the phone. for eg: if two cable from the back of the phones are plugged in to the switch.Nortel phones can do that... not sure about cisco..thanks
I have an UC500 and incoming calls works to the fax machine but outgoing doesn not work. I thought it should go on the outgoing dial-peer created. Is this wrongly configured?
I have a CUCM 6.1 install, using a 2811 with MGCP to telco. The site is in the middle of nowhere, so the only circuit they can provide is a voice T1 off of a "1A" switch. I am not familiar with a 1A switch, but appearantly it is pretty uncommon and...
Dear Support team,We are using CME 3.3 along with IOS "c3845-spservicesk9-mz.124-3a.bin".The problem is that 2 FXO ports are not answering the incoming call. While others FXO are answering fine.Those 2 FXO ports are 0/2/2 0/3/2!!Please find the attac...
Subject | Author | Posted |
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM | ||
04-28-2025 05:35 AM |
User | Count |
4 | |
3 | |
2 | |
1 | |
1 |
