Hi,does anyone know how much dlu consume vg 202 and vg 204 ?
We want to use cisco 7960G ip phones within our network which is secured by 802.1x but we don't use a call manager.I don't have a security menu on the IP phone ( version 07.5 ) and according to some research this is because I'm missing a ctl file on ...
I have a client who wants to deploy IPT for voice conferencing. He has thre offices (Nigeria, Kenya and ghana). He wants just two IP Phones at each of these sites. He intends to do voice conferencing within these three sites and is very cost conciuos...
All,Can anyone recommend a procedure for this. We have a unity failover pair VM only running out of space on the C: drive. This is because during the installation the procedure to move the logs and DB to the D: drive was not performed. If I try to de...
Hi all,CCM 4.13. The main site is ASA 5520 and connect to ASA 5505 (branch site with Static ip address DSL), EZVPN connect between each other.The ip phone connect to ASA 5505.It doesnt matter which side calls another side, it has one-way voice.The f...
I have already set a logo in idle url opction in CME7.0. for 7940 and 7960 but because of the difference of the size with 7911 and 7912 the logo is not displayed in the last ones. is it possible to set the same logo taking into account different size...
Hi,We have a Unity 4.x server that is unified with AD/Exchange 2003 (off box). We need to create new AD accounts for all the Unity users and then change the Unity user account to use this new AD account. Is there a way to easily do this instead of ...
Recently our company brought a SME business about 350 employees. They are using CUCMBE for voice requirements - voice and messaging. CUCMBE is running on a MCS-7828I3 server. With M&A activities it comes with organisation restructure. Decision from ...
Hi,Our CU is using IP trunk from service provider to make ISD calls which is terminated on our cisco router. We have configured this as H323 gateway in CUCM 6.1 and IP-IP gateway on this router. Refer to attachment for more deatils.We are facing issu...
Hi, Anyone tested or running this facility, can you let me know the link for some document of the same or if i can get some informations on this would be of great help. Thanks in advance.
I have Cisco UCM6 setup and have the following issue (or situation).I'm trying to associate the User ID to a phone for Mobile ConnectHowever, the Owner User ID is greyed out under all Phones.Is there something I need to do to order for me to make cha...
MWI does not work newly created extension outside of the default range i.e. 201-252. For e.g. i create a new extension "7514" to match with my isdn 4 digit suffix. I then create a user and associate a VM to it. VM works but MWI doesn't..Any ideas ple...
I installed an attendant console on one of my sites and it was fine for two weeks. Now the receptionist can login and she is on line but its not showing her who is ready, busy,etc , its only showing question marks (???). Thanks.
Hi All, We have a cisco 3845 router and we are trying to figure out,what all hardware/software components required to configure SRST on this router. Any help would be appreciated.Thanks RegardsAnantha Subramanian Natarajan
Hi All,I am facing a strange issue. i am having cucm 5.1, and configured an ftp server on pc to obtain the cdr flat files. The issue is the Disconnect Cause code is not the correct cause for call disconnect. Disconnect cause code for calls between tw...
Subject | Author | Posted |
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-22-2025 08:53 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
5 | |
4 | |
2 | |
2 | |
2 |
