IP Telephony and Phones
Labels
we are trying to connect a matra PABX on a 2801 gateway with ccm 4.1 (mgcp)we crossed pin 4,5 and 3,6 on the RJ-45 cablegreen LED 0K is ON when we call a matra phone (PABX) from an IP-phone, we have busy toneshould be a problem with TEI ?debug isdn q...
Hi,i have a customer with Vg224 extension 2003 (connected to fax machine), the VG 224 is configured as MGCP.lines are always hanging on the PSTN Voice gateway.I have tried a lot of IOS on the VG224 with no success.please note that no other lines are ...
twissam by Level 1
  • 574 Views
  • 6 replies
Using CM4.1.3, we want to automate the process to extract raw CDR data on a monthly basis. Like on 1st of every month, the raw CDR data for past month is extracted. Any ideas???We have an estimated 90,000 - 100,000 calls monthly.
agup by Level 1
  • 454 Views
  • 2 replies
Hi, Is it possible to setup RTMT to send reports to "Report Archive" like NumberOfRegisteredMediaDevicesIncreased and NumberOfRegisteredMediaDevicesDecreased. Also in graph form?How?thanks
redrobish by Level 1
  • 488 Views
  • 2 replies
Hello,I have (2) 7905 Cisco IP Phones and (2) 2800 Cisco Routers I am using for a test bed. I can set up the test bed manually so that telephone connectivity is available by manually configuring the phones and routers. How do I go about setting up th...
hi, please i have a problem with the auto-attendent, i have changed the welcome vocal messages an all the other (AABuisnessopen....), the problem that in the end, the old message comes after. i want delete it.also with my new message( that i have alr...
a.rayen83 by Level 1
  • 318 Views
  • 2 replies
I'm using CM version 4.1(3). At one of my remote sites using a VPN as the WAN connection I keep getting disconnect messages on the Attendant Console. When that happens it causes the receptionist to not be able to answer the call. The call usually r...
tpage by Level 1
  • 452 Views
  • 4 replies
