IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5679 Views
  • 14 replies
there is no CUBE between the telco and CUCM Could you provide some guidance on how to resolve this issue?* this call flow work on another telco.*Works for landline calls but not for mobile calls
1620415 by Level 1
  • 168 Views
  • 4 replies
Hi,I have four SPA303 IP phones which I’ve wiped and reset, and can access from the browser using the IP gateway. I’m looking to use these phones for internal calls only. Can this be done without any hosting service, and is anyone able to give me som...
#Team #Cisco #CommunityI need information if Cisco Call manager BE 6000 M6 running with V12.5 can be integrated with UCS-C220-M4 running with V11.5?Can I assign BE 6000 M6 running with  V12.5 in an existing cluster as a subscriber Node, where there a...
Hello all,  I've 2 CUBEs in production that are fine, however recently installed 2 new CUBEs with a new SIP service provider trunk. I have 2 different call manager groups, inbound and outbound works with a 1st call manager group. But if I change to t...
Unanswered Topics
