Hello. UC540 862. I have a door intercom i have patched into the phone system via FXS port (will not use FXO). When the button is pressed on the door intercom, you get a dial tone over the speaker and the FXS port is open. Is there a method to h...
Hi, Does anyone know why the SPA-1001 doesn't have the +10.30 in the time zone settings? It goes from +9.30 to +10.00 then +11.00.How can I adjust for daylight saving? Perhaps something has to go in the daylight saving time rule. ...
Hi all,i have an issue with the CME GUI.normally when we add new phones to the network the phone will appear on the GUI.but one of the phone is not appearing.but this phone is registered.can able to configure using CLI.what could be the cause?thanksk...
Hi experts, we have an high mortality of Cisco Linksys Power supplies used for SPA2102 and WRP400. The duration varies between 8 months to 12 months.The power supply model is 5V 2A PSM 11 R. What is the cause in your opinion?Could be related to elect...
Hello, we have a uc560 with the latest ios on itwe have a SIP trunk plugged in to the UC560, our problem is that incoming calls show "unavailble" as the caller id, instead of the numberhow could we change that to indeed show the calling number?thanks
Hello, we are installing a UC560. The customer has a Bogen HTA-250A and an ATA 186.The ATA was not used to connect to the Bogen before. They'd like to integrate it to use the IP phones to page in the plant area via the Overhead system.I've added th...
Hi, I recently purchased two SPA502G, refurbished from eBay, they are password protected is there a way to hard reset or force it in to recovery mode?I have emailed about the passwords but they couldn't trace them so I was refunded.Many thanks in adv...
Hello allWe have found an issue on muliple SPA models for example the SPA525 that the phone sends back to the switch a 486 after 30 seconds of CW.Where is the setting to leaghthin this?Thanks in advance!!!
Hello,I am facing issue with ip phone SPA525G2 (software version is 7.5.2c) where as we would not be able to make incoming call transfer to other ip phone extension, call hold & call resume (retrive).SPA525G2 is configured with UC560. Please find att...
Good morning sirs,I finish config my uc but isnt make call to voip server, just to pstn. I put the preference as 1 to sip and 10 to pstn. I dial and wait and wait.... and go by pstn. On my sip server my uc show me ok in registar and dont have no one...
Is it possible to re-program an unused Line Key light (button ?) so that it is labelled DND and stays RED while DND is activated ?When I use DND, sometimes I forget that its activated.TIA's
Hello,Any chance of enabling a LAN ONLY mode in the next UC320W firmware so that it does not have to be the gateway for the phone network?It's predecessor the SPA9000 had this capability and worked fine. I like the UC320W but don't want to use it as ...
Have an spa8000. Did a factory reset with the voice menu and got a voice confirmation that the reset was successful. Acutally did it twice. But now when I try to log into the web interface with as "admin" and use blank for password, it dosen't work. ...
