I enabled meetme conferenceing through CCA and assigned extension 777 for the service.When I dial 777, I get a busy signal.How can I troubleshoot this?-Thanks.-Brian
We have 3 analog line coming into our UC500 with an auto attendant that bascially points everyone to the same call blast group. the call blast group forwards to a Sequential Hunt group if there is no answer and then to voice mail.I am not a member o...
I've been playing with a SIP trunk and have noticed a potential discrepancy between CLI and CCA 2.0. Using the generic SIP template.When entering the realm/domain configuration in CCA all boxes turn green and config is applied without problem.When e...
Hello,is it possible to setup a greeting message "Welcome to XXXX please wait all lines are busy" while all lines are busy and have the busy phone rings as soon as it is free again ? A kind of waiting message for the caller. In AA, it seems that we h...
HelloJust set up uc 500 from cca sofware with 2 bri interfaces all works fine except incoming caller id strips the leading zero. I searched on here but cant find a simple solution.Could someone explain in relative laymans terms how to do itThanks
We noticed at customersite and in out lab that the SPA525G does not recognize distinctive calls. Phone like 7971/7940 network does recognize immediately the distinctive call. The 79series phones rings on a internal call and external call different. T...
Hi,Have one customer who has a SIP provider in Norway. In sweden they are not able to get a SIP provider yet, so they want to use the CME in norway for outgoing calls at the swedish location. What is the best way to set this up??? They use site-to-si...
Hello... does the uc520 support GUI access by users to make changes to phones? I can't find any material in the configuration document. If I browse to the IP address of the phone I get the information, configuration, etc but no option to make changes...
Hi,I have a small query, something has gone wrong or something has changed that when I VPN into my homenetwork I can not access any of my local devices.My setup is as follows:Data 10.54.8.*reserved 10.54.8.1 - 10VPN Access 10.54.8.11 - 20DHCP 10.54.8...
I read somewhere that the new release has a time clock feature available. Does anyone know where/how I access this and is there reporting available? better yet where is there any documentation about this new feature and setting it up?
HI Community,I am having troubles registering a SIP device to our system, we are conducting a LAB test on a SIP/VoIP payphone, i understand that Generic SIP devices are not supported by Cisco, however there might some people in here that have managed...
We have been experiencing erratic call behavior on our ip phones since sometime now. For every 1 out of 3 incoming calls, the call from the outside goes directly to the user's voicemail or gets d/c even though the phone was not busy. We get an email ...
Hi,Simple little question hopefully, when someone leaves a voicemail the MWI doesnt seem to light up, however it is enabled and when I manually dial the extension I can get the indicator to switch on and off. I have left the settings as default ext A...
