Hi,I configure a SIP trunk using CCA between the UC500 and SIP Service Provider. I can receive calls from the SP, but I can not make outgoing calls. I issue the command :debug ccsip callsAnd I received the output in the attached file.
Upgraded UC500 to 7.0.3, factory default settings. Receive the following error when attempting to open the Voice configuration "Error:Voice Cannot open Connection" system counts down, progress bar stops, and never opens up Voice settings.No other i...
This should be a relatively simple on.Im trying to get a FXO port to call a blast group and then prefably a particular users mailbox.. in lieu of that the blast group voicemail.What is the best method for doing this.Im actually having an issue of a t...
I am confused about DID routing when the system is switched to night service. The DID translation tables specify only one destination. I have programmed the system (CCA2.0) to route to an external number at night in the Voice Section. Does this mean ...
Hi,I searched but was unable to find the answers. I am setting up some CIPC clients and I wanted to know where to find any documentation specific to the UC520 setup for these phones (if there is any). The clients see the UC520 but are unable to TFTP ...
We are currently quoting a UC500 system for a garden center that would like to utilize the Cisco wireless phones outside.Our initial examination leads us to belive to we may need to install 3 outdoor wireless AP's. I have a couple questions however a...
Hi all,I'm doing the lab attached, that include a sim of "Generic SIP Service Provider". I want to know if i can configure an UC500 or CME router acting as "Generic Service Provider" and how can I do that.Thanks
We are programming using CCA 2.0 and have found that our Call Blast Groups are disconnecting. The system is programmed to ring to a blast group then overflow to another Blast Group with the same plus a couple more members. On this group i set the ove...
Hi,I just upgraded my UC520 to the latest code, and it updated my 7970, but now I've lost the Add button in local speed dials?OS Load: cnu70.8-4-1-23.binCheers Bob
Buenas tardes!!Instale un UC500 en mi red, todo funcionaba bien, pero se adquirieron pc´s con windosws vista y no salen a ciertos sitios de internet y al messenger de hotmail.Las pc´s con windows XP no tienen problema.Si quito el UC500 y dejo el mode...
I've got an issue with my CIPC phones connected to our UC500.They are all displaying time 6 hours ahead of the current time. All of my devices, UC520, CE520 and the AP521 are all configured for the correct time, and my IP Phones all have the correct...
Hi to all,I've a problem with the shared and status on my VOIP solution.I alwasy need to know the state of the voice lines in the phones, but this feature don't works as I expect.I see the line status but the state isn't always correct, an example wi...
Hi,Im doing a CCA Lab (UC500-CCA-First-Look-v1-Lab4), but there's a section in a lab the requiere to use the unity express Web config, but when I try to click on:Configure>ExtensionsI get the following error:Error: Unable to login as administrator to...
guys,i have setup ezvpn server on the uc 520 and ezvpn client on cisco 871. i have doubt in dealing with my vlan. by default, there are multiple vlans, such as vlan 1 = data, vlan 100 = voice, and loopback0 = service engine. i changed my service engi...
