Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Any chance we might see 802.11k and 802.11r standards implemented with any future 802.11ac Wave 2 WAP's for small business?Does either require a central controller, or can this be accomplished through WAP's talking to each other in a cluster type env...
Hi All,Having a bit of a strange issue with our Access Point at the moment. I recently set up a WAP4410N as our main WiFi hotspot using WPA2 encryption and it seemed to be working fine for all users, We had no issues when connecting Windows 7 laptops...
Hallo - I installed 3 WAP371 and when client move to another, powerful AP, the sticky on AP1 …to reach higher throughput, I installed three WAP371. The modern Clients (e.g. iphone 5s,6 , macbook pro 2014) use the 5GHz-band. In a Wifi-Scanner-App on t...
With the Ubiquiti WAP's, I have the ability to create user groups that can restrict bandwidth. I can then assign a user to one of those groups. For instance, if someone is hogging up bandwidth, I can limit them to 5 Mbps downstream and 1 Mbps upstr...
Im using the wap371 with 2 wireless Networks. One with WPA Personal and one with WPA Enterprise.The WPA Personal Network is working fine with both Firmwarereleases. (1.1.x.x and 1.2.x.x) I have only Problems with Windows Clients who are not a member ...
On my LAN there are 3 Cisco WAP 561 APs running in a Single Point Setup. Do I need to mark all of them "Trusted AP" in the Rogue AP Detection also (meaning one of them having the respective other two marked)? Thanks in advance!
Hi, I'm trying to upload a certificate generated by our private CA to the WAP121. I've tried the certificate in both Base 64 and DER format from the MS Cert Server. I attempted to rename the extension to .PEM but it doesn't upload. I've tried using ...
Are there any FCC regulations pertaining to connecting an outdoor antenna that is mounted on the outside wall of a building and connecting this antenna to an access point that is mounted on the inside wall of the building? I am looking at installing ...
Hello, I'm trying to set up my Guest WiFi VAP on my Cisco WAP561 so that it only allows guest users to access the internet and none of the local services. The network topography is simple; Internet -> Netgear Cable Gateway/Router -> TPLink PoE Injec...
I recently got an 1602i-K9 access point and I can not enter a configuration part : * I do not have the static address management so I cann't use web browser * When I plug my 1602 AP on a dhcp server, the bvi interface takes an IP address, I cann't ...
So I am having an issue That i think is not easy to solve. I have a brand new out of the box AIR-CAP2602i-A-K9. ...and thats all I have! lol i do not have controllers nor any other cisco equipment. (Except some security device but i dont think its ...
Bought an used SRP547W off ebay then realised that the unit is locked at service provider default.I only got the user level login and password.Is there a way to recover the admin account and password?I think I need the admin account to reset the conf...
Hi Cisco,Just deployed the really new firmware V1.2.0.2 (12 June 2015) for the WAP371 and noticed that 2 x Nexus 5 phones could no longer connect to the WiFi (no other devices seemed affected) on either 2.4Ghz or 5Ghz. I rolled back to the previous v...
