IP Telephony and Phones
Labels
Hi,Check out this new article about integrating Cisco Unified Communications Manager 9.1 with Cisco unity Connection 9.1.There is Cisco Unity Connection integration with Microsoft Active Directory as well. https://edsonvuma.wordpress.com/2015/12/17/i...
I changed the name of the Publisher running 9.1 from IP to a FQDN. I can ping the name from the Publisher, I can resolve from the Publisher. All address of DNS/Domain name everything has been changed and everything appears to be fine but I cannot get...
miket by Level 5
  • 1294 Views
  • 3 replies
Hi, I have a customer on CUCM 8.6 and they have just bought an Active/DMS call recording solution. They have approximately 600 extensions using a mix of Extension Mobility and "hard coded" phones. I'm trying to find an easy way (via csv file) to upda...
We have a need to use the Cisco IP phone system to call an ATA 190 device that is connected to a Speaker, so that we can use it as an intercom device for a mechanics shop.  Anyone have some idea of what we need to do to make that work?  Right now I c...
tnorman56 by Level 1
  • 296 Views
  • 2 replies
Hello Community, We are running CUBE and UCM 10.5.1 for some time now for all voice and are having problems migrating our fax services from TDM/PRI's to SIP.  Verizon does not support T.38 re-invite and we use G.729 as our preferred voice codec. Does...
Hi all, I am going to change IP phone agent phone services URL IP. After changing IP,  If I click on Update Subscription will it impact anything? will it restated all the phone because enterprise subscription has been enabled on our cluster. please...
