IP Telephony and Phones
Labels
Hi,I am using SIP trunk and have 10 DID numbers for FAX machine. I have to configure FAX with IP Telephony system, I am using ATA 186 to support fax. I just go through the Cvoice-Book, I come to know from internet, that lot of user facing problem, lo...
Hello,I have recently been struggling with DTMF relay configuration in which the provider has issues with in-band DTMF transport and has requested DTMF's to be delivered out-of-band. Examining the SIP INFO and the SIP NOTIFY methods for out-of-band D...
Hi,Im just after some information of whether ive configure my VoIP test network correctly. Im using 48Port POE 2960 and Siemens Openstage 15 phones.Switch Configlldp runinterface FastEthernet0/1 switchport access vlan 125 switchport mode access switc...
Si by Level 1
  • 3885 Views
  • 3 replies
Hi All, I have created some 4 digit DNs in CUCM to use as speed dials, these are forwarded (Forward All) to mobile numbers.  When you dial one of these 4 digit numbers eg. 4444 from an IP phone it displays the text I enter in the 'Alerting Name' fiel...
Can I go from        Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)To version 15.1.4M6 or is there a couple versions i have to upgrade to first before i go to 15.1.4m6.Thank You.
I have sort of an needle in a haystack issue I am dealing with and hoping someone might be able to point me at something to try or look at.I have a remote location at completely random times and from completely random numbers when the location is cal...
