Need some help in setting up the system audit logs or alarms/notices to a remote server for monitoring/analyzing purposes.Using CUCM 7.x cluster.
Hi,I am using standalone CSA 3.0(2) on a unity server 4.X (Windows 2k platform) and we recently installed McAfee Virusscan Enterprise 8.5 on the server.The Anti virus is working well but the autoupdate task is blocked by CSA agent.Is there any way to...
Dears,I have one 3825 device with 3 ISDN interfaces attached to one PSTN, one IVR and one PBX links.PSTN ------------ Cisco Voice Gateway ------------------ IVR . . ...
Users users hear dtmf tones while talking why this can happen ? The company has a pbx and it is connected to cisco IAD with PRI line, and this IAD goes to service provider with IP. Any idea ?Regards.
Hi dear community,I would like to know if the ASA have the ability to end SRTP and IPSEC (for securing signalisation) of a MGCP controlled gateway:CUCM ------- [ASA] ------- Gateway -------(PSTN)-------phones | ...
Hello Experts,I've just recently purchased a 2951 voice gateway but unfortunately can't configure it in my current version of UCM (7.1.2), it's not an option in the drop down list of gateways. I've read quite a few posts here and from what I underst...
Hello,I use a vg224 with sccp & fax-protocol cisco. Faxes national work but with one international fax number it doesn't work. When i use a direct line it works.I don't know what's going wrong. When i use a phone with the same css, i can call the fax...
i have a vic-2did, and my background information like the topic :http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008010ff92.shtmland i have 3 did lines.and i had config voice port in immediate start:voice-port 0/1/0 signal did...
I am having trouble getting b-acd to work with unity express. When I dial the pilot number for B-ACD from an internal phone it works fine, however when dialing the CUE AA from internal or over our SIP trunk the call disconects when selecting the opti...
Hi,actually I have 2 Question.1 - I have cisco cme with 6FXO lines when some one call the extension and no body answer I hang up the line but the fxo port keep on busy status for 55 sec after that it will release. here is the configuration file.no ip...
I am setting up a new CUCM7 environment which will be shared by various divisions of the Company. As such the Server environment is in a DMZ. We are trying to place the Gateways inside the firewalls (on the same networks as the phones) and have cre...
Hi,We are running UCM 7.1.3. Customer brought up Cisco 9971 Video Phones,but when we are adding these phone we are not able to see the Cisco 9971 phone in the list.Please suggest us to resolve this one. Please let us know if we need to add patch,if i...
Hi;I want to block outgoing calls for an extension. The extension will be call only internal number which is a 3 digit number.Here if my config:dial-peer cor custom name internaldial-peer cor list 1xx member internalephone-dn 2 dual-line number 101...
I install DMA 6.1(3) in CM4.1(3), DMA works successfully, it can create a successful tar file for upgrade.As I install CM6.1(3) on new server with the DMA tar file on MCS7835I3-K9-CMC2, it indicate the platform cannot supportthe installation of CM6.1...
hi friend ..what is the right VOIP GSM/CDMA gateway ???????regards ...
Subject | Author | Posted |
06-04-2025 11:19 AM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
4 | |
3 | |
2 | |
1 |
