Dear All,Recently just upgrade to CUCM 7.1. I facing user can't create meet me conference. Ad hoc conference no problem. When first user press meet me button from phone and dial meet me number, phone show connected. When second user press meet me...
Hopefully a quick and easy question for someone out there?We are planning our CM upgrade from 6.1(3) to 7.1 and want to make sure our VG200's that are currently in place are compatible.I've looked in as many places on the Cisco site as I can think of...
Good day all, Can anyone help with the following problem? I have CME 4.3 (flash:c2800nm-adventerprisek9-mz.124-15.XZ.bin), one ip phone 7965G with Version SCCP45.8-4-2S, and i try to install the 7916 module without a result. According to the follo...
Hi all;I have an upgrade from 4.1 to 6.1 and I have VG200 and a couple of CMM modules...I need a document from cisco that tells the minimum IOS version for VG and CMM in order to work with new callmanager version...I tried so hard searching for any b...
As you all well know, once you hit a LED button line to diala number, the Short Name on display no longer shows up.Is there anway to write a function in the extendedfunction line (see below) in order to have the Short Nameshow up on display when dial...
one of my client having vmware server, asking do we can run CUCM 7.1 in vmware server itself [ like Unity 7.1 ] please some one light me on CUCM 7.1 support on vmware for 550 users.
all the calls sound a bit muffled on my 504g phone, almost asif you want to add treble to the background. Is this normalas opposed to regular calls on NON IP phones?Is there anyway to adjust this?Thanks
Hi All,I integrated with third party voice conference solution called Astrisk.it is integrated with CUCM 6.1 through SIP trunk.When I reach 50 participants per conference I can't add more ip phones to the conference;i get fast busy tone.Is there any ...
Hi all,I'm experiencing problem in incoming calls after changing the communication protocol with the CUCM from H.323 to MGCP.Depending on the incoming call type I'm having different behaviour:Some calls (typically from digital devices like mobile) ar...
Hi all,My customer needs to make voice conference solution lets users to join a confernces from anywhere in the world but after prompting them to enter conference ID & conference password.Different users can join different conferences according to Co...
hi,i want to change the background image of 7970 ip phone screen..i made a fullsize image with a name mzecFULL.PNG(320 pixels (width) X 212 pixels (height)) and a thumbnail image with a name mzecTN.PNG (80 pixels (width) X 53 pixels (height). I also ...
Hello,I have to backup about 15 CallManagers (mostly CUCM6.1) to an centralized management debian server via SFTP protocol. The problem is the server accepts ssh connections authorized with ssh-keys only, not pass-phrases. This is how its said in int...
hi,due to some errors on ip phone i have to change the firmware (load) for the 7970 ip phone... do i need to remove the old firmware file from tftp of cucm7.0 and then upload the new firmware file??? or is there any other proceedure.RegardsNareh
We are currently using CCM 6.0, Our Users Directory is in “Arabic”, for users with Arabic Locale we can check all Arabic names from the directory but all users with English Locale cannot & names are displayed as [][][][][][].Any solution or suggestio...
Could somebody pls advise how to update infoon my IP 504G phone as per attached pictures.I am using Interner Explorer 7.0.5730.11 Also, is there an easy step-to-step procedure to adda .bmp logo to the phone? I understand I need togo through a tftp se...
Subject | Author | Posted |
03-25-2025 10:10 AM | ||
03-25-2025 08:49 AM | ||
03-25-2025 06:06 AM | ||
03-21-2025 01:42 PM | ||
03-20-2025 05:12 AM |
User | Count |
5 | |
2 | |
2 | |
2 | |
1 |
