IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6147 Views
  • 14 replies
Resolved! CSCso81531 Bug
Hi,I've CSCso81531 Bug present on a cluster of 2x CCM 6.1(2), and it says is fixed on 6.1(3.1000.16).But there are later versions than that, but Bug details doesn't mention them. So it will be solved if I upgrades to another 6.1(3x) or 6.1(4) version...
I can't get the Communications Manager 7.1 DVD to install on my 7825I4. No problem on a 7825I3...It's always saying something about a "HW type [Vendor/Product] NOT SUPPORTED"After looking at the HCL it should be supported...Who is wrong, installer ...
What are the upgrade options for someone that currently has Call Manager 4.x and wants to upgrade UCM 7.x when they dont have UCSS? Do they have to purchase all new licensing, or is there an upgrade part number they can use to migrate the licensin...
I am trying to make a call from my Germany office to a fax machine in Colorado. However I keep receiving this ISDN msg everytime... and the call just hangs and you can't hear anything. MGCP GWCM 4.2.3000764: Jun 23 14:39:33.723 CEST: ISDN Se0/0/0:15 ...
dvanzee by Level 2
  • 1701 Views
  • 5 replies
