IP Telephony and Phones
Labels
Guys,Got a problem with some overlapping numbers and tried using the the line device CSS Approach as outlined in the SRND but feel I have an issue based on the CTI port caveat. I.e the CTI port wont follow the Line device CSS approach.The phone syste...
bigcappa1 by Level 4
  • 674 Views
  • 4 replies
Hi All, is there any way to split subscribers in unity connection? for example incoming calls hit to auto attendant, then caller can dial extension at any time. is it possible to allow caller be able to reach only certain subscribers? I did CSS and p...
hi i have this issue, and i want to know if someone knows how to fix the issue up.the issue only happens to the outgoing calls, the call setup is:ip phone-> ucm -> e1(qsig) -> panasonicthe call establishes well, but the cisco phone does not heard th...
