IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5797 Views
  • 14 replies
Hello guys, i would like to know if fax passthrough is supported with a SIP Trunk with "MTP is required" checked ? I had to check the "MTP is required", because of conferences with outside users that did not work and because of PSTN prompt not played...
jtoque by Level 1
  • 2061 Views
  • 3 replies
I am getting the following error every 15 minutes in the event viewer on my ipccx server. crs version: 5.0(1)_Build433thanks!Event Type: ErrorEvent Source: Cisco Desktop VoIP Monitor ServiceEvent Category: NoneEvent ID: 4Date: 11/6/2008Time: 9:42:...
jones2sr by Level 1
  • 475 Views
  • 1 replies
Hi Everyone,Cisco have just released CUCM 6.1(2)su1a which is released to fix, amongst other things, an issue whereby the CCM Manager & CTI Manager Services crash after 248 days.I am currently deploying a CUCM 6.1(2) cluster so am implementing this S...
Hello everyone,I have a customer with a remote teleworker need. They have an analog line at a work from home site. they want to put an IP phone there but want the IP phone to use the local analog line for all outbound calls. They want to do someth...
When dialing main number that routes over analog line to FXO port I recieve a busy signal. I have set up extension 1001 as automated attendant extension number. This number works fine if I dial from an IP phone, but rings busy if I try to dial from o...
jsheppard by Level 1
  • 823 Views
  • 6 replies
Hi,I have urgent telephony, and I need this:I have 2 lines (First one is normal call and secondary is for urgent incoming calls):If the end user using the first line and have a call incoming in the second line (This line is used for urgent incoming c...
I am trying to back up Cisco Unified Presence Server 6.0.4.1000-4 using Titan FTP server 6.24 which is Cisco's recommended SFTP product for Windows.It fails when I try to add the backup device.The same SFTP server works fine for CUCM 6.1 and Unity Co...
