IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6332 Views
  • 14 replies
I have an issue with Unity 4.2 whereby the user hears “This system is temporarily unable to complete your call…” immediately after logging into their mailbox. The trace logs indicate a failsafe condition has occurred as below. If anyone can t...
by Not applicable
  • 529 Views
  • 2 replies
Does anyone know why you would not be able to edit a Hunt Group anymore?We are adding additional phones and users to an existing Hunt Group. The new phones are associated with the ac user and everything.No matter where we place them in the Hunt Group...
Hi, I have a technical question related to Cisco IPCC products in one specific scenario. I have a Costumer who whish to have a contact center in a centralized site in Madrid, Spain, and two or more sites where the agents will be, one here in Mexico C...
miguelho by Level 1
  • 280 Views
  • 1 replies
Dear all,Currently i have a setup that's like this PBX -> h232 gw -> CM -> gw -> pstnSo we need to capture CDR of the calls made by the phones on the PBX to PSTN. Are we able to do it using CM's cdr? Any leads on this would be great. Thanks
wboonshen by Level 1
  • 381 Views
  • 1 replies
guysim having an indirect voice issue. my phones at a remote location goes down for half a second (probably once a day trying to go into SRST mode). ive identified the issue but that about as far as i can get. here it is. if i clear the counters on t...
a.gooding by Level 5
  • 351 Views
  • 4 replies
I have a user who has his volume on full capacity and he has saved this setting. He states he would like the option of having it lounder than it is. At the present it is on full volume with no capacity to make it louder should he wish to have it loud...
DerekM by Level 1
  • 2652 Views
  • 4 replies
On CallManager 4.x, I am considering creating a publication of the CallDetailRecord table using push replication, so that we can access the CDR data away from the CallManager.Is this a bad idea or is there anything I should look out for.Thanks for an...
Resolved! UC and router 1861
I have the following requirement:IP telephony for 8 user, about 6 agents will be using simultaneously on PSTN network (approximately 5 incoming calls and one outgoing calls using head phones), voice mail optional My solution is:Cisco part no. C1861-...
dshrestha by Level 1
  • 445 Views
  • 1 replies
