IP Telephony and Phones
Labels
Hi everyone,I'm having trouble trying to route calls through an IP trunk for some reason.I've got the following two dial-peers:!dial-peer voice 5 pots description Primary Outgoing Line preference 1 destination-pattern 1T port 0/1/1 forward-digits all...
We continue to have random WAV files disappear.Ran DBWalker and found the following error,1218:(error) greeting is set to use a missing WAV file path:D:\CommServer\Stream Files\ConPlantMainAutoAttendant_Standard_MrGreeting_0ca980e3.wav How do we proa...
We have one subscriber of the 4 sub in our cluster that has occasional high CPU and we go into Code Yellow. Started about a week ago. Happens about 10 times during the business day.All subs have about the same load with number of phones/gateways, s...
Hi all,Why my 7970G is displaying wrong time while all others are with the right time?I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.I've set the time-zone parameter on telephone-service.This issue is driving m...
rafael2gc by Level 1
  • 377 Views
  • 3 replies
hi we have a centralised setup of ccm 4.2(3) and the ip phones are in different cities,we also have a trunk to USA also.i have blocked offnet to offnet calls for the external transfer to PSTN.But as the PSTN line is connected to the central site gat...
kumar3880 by Level 1
  • 309 Views
  • 1 replies
