IP Telephony and Phones
Labels
Hi,Do you know if it's possible to send short messages to an IP phone through the based on PC attendant console?I.e; when a visitor arrives the attendant informs the meeting owner that his visitor is there.Thank you for your support.
ypaon by Level 1
  • 387 Views
  • 1 replies
Hello All , need urgent help please , I have a router with FXS 4 - ports , and we connected them to PBX ( FXO port) , the problem that :When we place a cll from the network to any ext behind the PBX , all the FXS ports on the router go off-hook , a...
Our servers are reaching end of life so we decided to upgrade. However, we only purchased the servers, thinking that we could use the 4.1 software that we already have. I just received the new MCS 7835 H2 servers and our software is telling me that...
cerp by Level 1
  • 360 Views
  • 1 replies
I need to how to configure "external phone number mask" on a DN configuration but still have actual phone DN displayed on the 7912 (DN 1001-1004 per site). I do not want to have route patterns as I would need 2-3 per site (500+ sites).I basically nee...
I have a 7970G which will not power up after upgrading from 4.1(2) to 5.1(3).The phone is getting power from an external power pack. When I unplug the power pack and network cable and plug them back in the mute light flashes then the speaker light t...
bgibson by Level 1
  • 538 Views
  • 2 replies
Hey guys --In the past I have been able to transfer directly to VM by creating a CTI PT with the extension *XXXX; CFA to VM with a VM profile that has a mask of XXXX.Unfortunately, I have not been able to get this to work in CM6.Let me know if I'm mi...
ouhakheme by Level 3
  • 406 Views
  • 3 replies
Hi,so we have three types of phones, 7912, 7940 and 7960. users would require logging into all the different types of phones, therefore, one week a person tat usually uses a 7912 would require to log into a 7940 etc etc. the reverse would also be req...
a.gooding by Level 5
  • 626 Views
  • 3 replies
