IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Hi Everybody,After applying SR2b patch to CCM 4.2.3 SR1 we've got a problem when in CCM Administration, any screen that we change settings and click Update will freeze and stuck with Processing.... message on the bottom of web browser. If you open an...
klondike by Level 1
  • 452 Views
  • 5 replies
hii have ccm 5.1 i have configured time group GMT+3 but time appears incorrectly on ip phones, i have configured this previously on other ccm's without any problem does any one have ideas on what may cause this problem??thanks
I'd like to set up VG224 to support analog phones, modems, and fax machines with extensions on DID blocks. I've followed Cisco's SCCP Controlled Analog (FXS) Ports doc, and have successfully configured a voice port for an analog phone. However, the s...
admin_2 by Level 3
  • 953 Views
  • 7 replies
Hi,I need a help to recover the phrase password, which I lost long back. I am trying to install plug-in Digit analyser, it asked for the phrase password which I dont remember. Please let me know the procedure how to break/recover the same.Thanks in a...
Hi pros,I have CME 4.0 and 2811 router with several IP Phones. I have configured some of my clients in my local network as an SIP client. They will use X-lite softphone. Everything is fine, they can register and call.Then i decided to deploy X-lite t...
ahmet-saat by Level 1
  • 1133 Views
  • 10 replies
