IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6207 Views
  • 14 replies
Can we have a Publisher and a Subscriber in two different locations for a CCM ?If one of these goes down for some reason will the other keep the phone up and operational and are you limited to a certain time it keeps them working?
Mojo1 by Level 1
  • 255 Views
  • 2 replies
I have a route filter that I'm trying to implement. The idea is for local calls, to allow 10 digit dialing as long as the area code is 206 or 425. The user can also use 7-digit dialing as well. I've configured the route filter as (AREA-CODE == 206...
i installed cisco CUOM,AND I HAVE TO INSTALL THE 1040 SENSOR BEFORE IT WORKS,I CONFIGURE THE SPAN PORT ON THE SWITCH,AND PLUG THE 1040 SENSOR,BUT IS NOT GETTING THE IP ADDRESS,AND INEED A HELP ON HOW TO COPY THE 1040 SENSOR DEFAULT IMAGE FILE TO THE ...
SELOMECIS by Level 1
  • 1022 Views
  • 7 replies
Hi!I?m trying to set the panish localization in a ip phone model 7906G. I?m looking this table http://www.cisco.com/en/US/partner/products/sw/voicesw/ps4625/prod_installation_guide09186a00806dad6a.htmlAnd I have tried with the files from here:http://...
jumaca303 by Level 1
  • 320 Views
  • 2 replies
Hi, When you've got a bandwidth statement,does that refer to just codec bandwidth, or does it include layer 3 & 4 overhead? and, when a call crosses 2 zones, does the bandwidth used for a call get deducted from the source zone or hte destination zon...
lgontarsk by Level 1
  • 322 Views
  • 2 replies
