IP Telephony and Phones
Labels
Ext. 3996 is trying to forward to x3986. Ext, 3886 phone indicates the calls are forwarded to x3986. When you dial 3996 it forwards, rings four times and the greeting heard is ?the extension is not available?. But when you directly dial 3986 (x3996 ...
Hi have a shared line accross a 7912 and an ATA for some reason when I try and call a route point from either the phone or the device plugged into the ATA I get a busy tone , I have checked CSS and Device pool , region and codec and all are correct h...
Hi,I have a CallManager Express 4.0, I had opened in GUI but I am unable to add the phones. I had downloaded the lates basic files for GUI (cme-basic-4.0.0.1[1]) and GUI Files.But when I added IP Phone in Router I am able to modify the same in GUI.Is...
Resolved! CDR Problem
I have CCM 4.1(2). My CCM stopped making the call detail records all of a sudden. All CDR services are up, SQL running fine, no issue, nothing in the event logs but its not working. Any clue how to diagnose the problem?? Thanks in advance.Sheeraz
When we receive an PSTN call on the ip phones(7912). Upon answering our users give a standard greeting of hello, their name and the company name. The person calling doesn't hear all of this, Usually just the very last bit. It seems there is a delay i...
silex by Level 1
  • 410 Views
  • 3 replies
I have our main number (x1000) setup to ring all the phones however if someone answers a call then places it on hold it does not show on the other phones. Shouldn't it with the following config or am I missing something? They should be able to place ...
mike85719 by Level 1
  • 626 Views
  • 1 replies
