Routing
“Webinar
Labels
I have a setup in which i have 2 routers connected to same ISP A both via default route pointing towards ISP for internet.Now we want to add another ISP B on both routers however that ISP will use BGP with RIPE IP address over the internet.Now we wan...
From where to download the cisco images (Router and L2,L3 switches) for eve ng and which image will work good.Below is the list mentioned in eve ng but what is the proper way to download these imagesDynamips (Cisco IOS emulation)c7200-adventerprisek9...
Hello Everyone I have to set up an ipsec tunnel with Lo0 as source of tha tunnel. Nat is activated in My CE and in the ISP level (NAT444)All ipsec and Nat configuration is ok but, and as I know that for the NAT to work correctly, the packet should pa...
mrkassimi by Level 1
  • 263 Views
  • 5 replies
Hello Team,I have a topology as below;I have point to point connections to multiple partners who have different unique prefixes - to avoid overlapping of subnets.They need to access my internal resources - in this case vlan 50 and 70 for respective s...
fmugambi by Spotlight
  • 225 Views
  • 6 replies
Please refer the below topology,Client >>> Cisco router >>> Firewall  >>> Upstream device >>> serverI have set mtu as 200 in my upstream device  and as exepected when client access the server(http) the packets are fragmented.However when I set tcp-ms...
RobotAjay by Level 1
  • 172 Views
  • 5 replies
This is very high level, wanting to know if this is possible.  We're the middle man.  I don't have access to or knowledge of equipment or configs on the other providers.  Currently we are handed off a GRE tunnel to a router.  We have an ipsec tunnel ...
Hello,We have run into a situation where we need to load balance internet traffic outbound i.e. for wired subnets we want to send traffic via ISP A and for Wireless users we want to send traffic via ISP B.I am pasting high-level branch infra picture ...
Hi The DMVPN tunnel was reset, which caused the BGP session to reset as well. We observed that the DMVPN crypto socket is down. What could be the issue? We suspect it might be related to the ISP, but they have reported no abnormalities in their logsD...
Resolved! Enable SSH V2
Hi, i have a switch 2960 24TC-L with c2960-lanbasek9-mz.150-1.SE.bin and SSH v1 enabled.When i try to enable SSH v2 the swith tell me that i have to create a crypto key rsa. I generated the crypto key rsa with 1024 bits and when i try to enable the S...
Unanswered Topics
