Hi,I need to know if the 7961 IP phone support italian locale for uc500 and where I can find it.The bundle that I download contain only 7921.Thank you very muchBye
I have tested the account from outlook and the SMTP account dose no look like it is sending the message. Although, the cell phone notification works. any ideas this is a Comcast email address external to my firm. Is there a way to see an error log...
Can somebody confirm me that in UC540 and UC560 there will not be CLI access?If this is the case, Is there any method for debugging and troubleshoot without this?Best Regards,
previously one could update CUE either with the bootloader or with ftp from within the service engine, e.g.# software install upgrade url ftp://192.168.10.11/cue-vm-k9.ise.7.0.3.pkgNow with UC520 8.0 the names of the binaries have changed.(can't find...
Customer is having issues connecting their Cisco 7940 Phones to their SPA9000/400. The Cisco 7940 is currently running SIP, yet the device will not show up in the SPA9000 wizard. These phones were provisioned by their old ITSP, according to the prov...
I have an SPA3102 setup as a Local Access Number line on the PSTN port. I can call the PSTN number and it will answer and route the call through the virtual number connected to the port to my VSP and I can call an overseas number. But when I call the...
Hi Guys,When cisco IP phones boots i get presented with the cisco splash screen as if it is trying to upgrade the firmware then I get Auth Fail....This is after I upgraded to UC520 8.0.0 ......Can someone please help as the Cisco engineer told me to ...
I have been using the fax to voicemail feature for several customers, and they, as well as I, love it. The only issue I have is that the fax "mailbox" fills up. Unless I manually go into the mailbox and delete them. I have set the expiration to 3 ...
I have to install a UC 560 with a mix of Cico phones and Polycom IP soundpoint 430 SIP end points. Has anyone configured a SIP Polycom sound points to work with the UC500 seiers and what issues have yo urun into?
Hello there.One of my clients wants to call to his company UC520 from his cell and make calls from there to save rates, etc. I cannot find a config, implementation guide, to start with. I don't know what to search for.Thanks
I'm trying to get the SPA525G using the new SSL VPN feature but I keep getting "VPN connect failed." I ran the Wizard and punched in the VPN Server, Username, and Password. I was hoping this would of been easy because of the Wizard, but I guess not...
SPA3102 with firmware version 5.1.10GW (hardware version 1.4.5a) that keeps on loosin gthe registration of the PSTN Line only when connected remotely (outside of the local network where the PBX is located). My SIP server is based on PBX in a Flash, ...
Hi,I have a problem with a SPA400 constantly rebooting.The problem occured when I did some changes in the "Voice"-tab.I changed the "Caller ID/CP Tone Method" from american to european, and the SPA400 started rebooting constantly.The only way I could...
